Plugin Class
You can get access to the main loop of the Unigine engine by overriding virtual methods of the Unigine.Plugin class. This article describes the sample located in the <UnigineSDK>/source/csharp/samples/Api/Systems/Ffp/ directory.
In the C# API you can inherit from the Plugin class only once.
  • An example can be found in the <UnigineSDK>/source/csharp/samples/Api/Systems/Ffp/ directory.
  • C++ API classes Unigine::Plugin and Unigine::Ffp which have the same methods and behavior as in the C# API.
Plugin Class Usage Example#
C# Side#
To use the Unigine.Plugin class, you should create your own class and inherit it from the Unigine.Plugin class and override necessary methods, which the engine will perform in its main loop.
Source code (C#)
using System;
using Unigine;
class UnigineApp {
	class FfpPlugin : Plugin {
		private float time;
		public override void gui() {
			App app = App.get();
			time += app.getIFps();
			render(time);
		private void render(float time) {
			Ffp ffp = Ffp.get();
			// screen size
			int width = app.getWidth();
			int height = app.getHeight();
			float radius = height / 2.0f;
			ffp.enable(Ffp.MODE_SOLID);
			ffp.setOrtho(width,height);
				// begin triangles
				ffp.beginTriangles();
				// vertex colors
				uint[] colors = { 0xffff0000, 0xff00ff00, 0xff0000ff };
				// create vertices
				int num_vertex = 16;
				for(int i = 0; i < num_vertex; i++) {
					float angle = MathLib.PI2 * i / (num_vertex - 1) - time;
					float x = width / 2 + (float)Math.Sin(angle) * radius;
					float y = height / 2 + (float)Math.Cos(angle) * radius;
					ffp.addVertex(x,y);
					ffp.setColor(colors[i % 3]);
				// create indices
				for(int i = 1; i < num_vertex; i++) {
					ffp.addIndex(0);
					ffp.addIndex(i);
					ffp.addIndex(i - 1);
				// end triangles
				ffp.endTriangles();
			ffp.disable();
	[STAThread]
	static void Main(string[] args) {
		// initialize wrapper
		Wrapper.init();
		// initialize engine
		Engine engine = Engine.init(Engine.VERSION,args);
		// create plugin
		FfpPlugin plugin = new FfpPlugin();
		engine.addPlugin(plugin);
		// enter main loop
		engine.main();
		// remove plugin
		engine.removePlugin(plugin);
		// shutdown engine
		Engine.shutdown();
In this part of the code we create the FfpPlugin class which inherits the Plugin class and override the gui() method. We specified the render() method and call it inside the overridden gui() method. Engine calls this function before gui each render frame.
In the Main() method, we create an instance of the FfpPlugin class and add it to the engine by using the addPlugin() method after the wrapper and the engine had been initialized.
Unigine Script Side#
All the logic is implemented in the C# Ffp.cs file. There is only one command in the UnigineScript ffp.cpp file to show a console:
Source code (UnigineScript)
int init() {
	// show console
	engine.console.setActivity(1);
Output#
The following result will be shown:
Last update: 2020-01-14
