This panel allows to organize and modify the materials and can be invoked by pressing the M key (for other materials hotkeys see Controls) or choosing Materials tab on the Editor interface panel.
This article is deprecated and will be updated in the UNIGINE 2.4 version.
Materials Editor consists of three parts: preview panel, material tree hierarchy list and data related to the selected material (material tabs).
Materials editor settings
Preview Panel and Material Tree
The left part of the Materials panel consists of the following elements:
  • Preview panel — display the current material over the geometric figure, selected in the drop-down list: box, sphere or dodecahedron.
  •   List of preloaded material libraries — set load order, add, save or remove material libraries from the list.
  •   Save materials — save the material.
  •   Clone material — clone the selected material to the library with specified name.
  •   Inherit material — inherit the selected material in the library with specified name.
  •   Rename/move material — rename or move the material in the library.
  •   Remove material — remove material and all its children from the list.
  •   Assign material — assign material to one selected surface of the selected node.
  • Library filter — show all material libraries in the hierarchy list or filter the specific ones for displaying.
  • Search — search material in the hierarchy list by name.
  • Materials hierarchy list — hierarchically structured list of the materials giving material names and parent-child links. It enables showing only the parent materials and hide the child ones if necessary.
Material Tabs
The material-related data is grouped into four tabs:
  • The Common tab contains common material settings. These properties are the same for all materials.
  • The States tab contains a set of flags that will be used for a shader corresponding to the material.
  • The Textures tab contains paths to textures used by the material.
  • The Parameters tab contains parameters associated with the selected states.
Details on type dependent properties can be found in Material Class article.
Common Tab
The common tab has the following options:
Info
This section provides the information about the selected material:
Library A library for the current material.
Name A name of the material.
Parent A name of the parent material.
Children The number of child materials.
Transparency
This section contains transparency settings:
Preset Blending presets. One of the following can be selected:
  • Opaque
  • Alpha test
  • Alpha blend
  • Additive
  • Multiplicative
  • Custom
Src Option used to scale the source color (the color of an overlaying material). Available only when Custom preset is selected.
Dest Option used to scale the destination color (the color of an obscured material). Available only when Custom preset is selected.
Options
This section contains common material options:
Rendering order Sort order used by rendering transparent objects with alpha blending. Transparent objects should be set lowest order numbers and thus rendered first, while opaque objects should be set highest order numbers to be rendered last.
In order to control the rendering order, you need to set Materials settings -> States tab -> Ambient pass to Transparent for the selected material.
Polygon offset Polygon offset level used for the material.
Shadow mask A shadow mask of the material.
Viewport mask A viewport mask that allows to selectively render materials and reflections from them. (See the detailed info).
Two sided Render polygons, to which the material is applied, two times by lighting pass.
Cast shadow Render polygons, to which the material is applied, casting shadows from omni, projected or cubemap light sources.
Cast world shadow Render polygons, to which the material is applied, casting shadows from world light sources.
Copy settings Copy all material settings.
Paste settings Apply the previously copied settings of the material to the current one.
Last update: 03.07.2017
