Полезные советы
Trigger
A   trigger is a zero-sized node that has no visual representation and fires callbacks when it is enabled/disabled (an enabled callback function is called) or its transformation is changed (a position callback function is called). A Node Trigger is usually added as a child node to another node, so that the callbacks will be fired on the parent node enabling/disabling or transforming.
The enabled and position callback functions should be implemented in the world script.
The Node Trigger can work with procedurally created World Clutter objects.
The Node Trigger can be used, for example, to play a sound of thunder when a lightning flashes: when the lightning node is enabled, the enabled callback function that plays a sound is called.
Lightning node enabled
Adding a Node Trigger#
To add a new Node Trigger via UnigineEditor do the following:
  1. Run UnigineEditor.
  2. On the Menu bar, click Create -> Logic -> Node Trigger.
  3. Place the Node Trigger in the world.
  4. Add the Node Trigger as a child to a node for which callbacks should be fired: select the Node Trigger in the World Hierarchy window and drag it inside the required node.
Editing a Node Trigger#
To edit the Node Trigger, select it and go to the Node tab of the Parameters window. In the Node Trigger section, you can specify callback functions that will be called when the Node Trigger or its parent node is enabled/disabled or transformed.
Node Trigger settings
The callback functions must be implemented in the world script (on UnigineScript side). The enabled and position callback functions should receive a Node Trigger that fires the callback as their first argument. However, they can also receive a node or even no arguments at all.
The callback function can also take 2 additional arguments. However, you can set such callbacks via the code only. Via UnigineEditor, you can only specify the callback functions that receive 0 or 1 as argument.
Last update: 31.07.2020
