Landscape
The section contains settings that control rendering of Landscape Terrain.
Landscape Terrain rendering settings
All the settings are also available via Console.
Geometry#
Mask Dithering | Dither amount multiplier (in the [0.0f; 1.0f] range) used for rendering details of the landscape terrain. Dithering enables reduction of graphical artefacts in case of increased Mask Contrast values set per-detail. This is a global multiplier for dithering values set for each detail mask. |
Holes | Toggles rendering of decal-based terrain holes on and off. |
Geometry Progression | Progression of the Landscape Terrain geometry tessellation in the [0,50] range. |
Geometry Fade Lods | Intensity of fading between levels of geometry tessellation in the [0,1] range. |
Geometry Subpixel Reduction | Minimum ratio of a polygon size (in screen space) to the size of an area seen in the viewport in the [0,50] range. If the ratio calculated for the polygon is less than this value, such polygon will be removed. |
Geometry Polygon Size | Size of Landscape Terrain polygons in the [0.0001,1000.0] range, in units. The value defines the maximum allowed density of Landscape Terrain geometry. |
Visibility Distance | Visibility distance of the Landscape Terrain in units. |
Streaming#
Culling#
Cache#
Была ли эта статья полезной?
