Unigine.ObjectParticles Class
Inherits: | Object |
This class is used to create particle systems. The particles are approximated with a sphere. They can be of different types (see the details) and radius (that can change with time). They are emitted from different emitters (see the details) with a specified spawn rate. The particles disappear after the set life time period or culled when hitting other nodes. They either collide with the outer surface of the approximation sphere or intersect only by the its center.
The particle flow direction can be influenced by:
- Gravity
- Point force (see the details), which has two properties:
- Deflectors of two types (see the details):
- Physicals nodes
The particle system can also initialized before it actually appears, so that it starts to be rendered with already spawned particles.
A set of UnigineScript API samples located in the <UnigineSDK>/data/samples/objects/ folder:
Properties
WorldBoundBox WorldBoundBoxParticles#
BoundBox BoundBoxSimulation#
BoundBox BoundBoxParticles#
Vec3 WorldOffset#
int NumContacts#
int NumDeflectors#
int NumNoises#
int NumForces#
vec3 Gravity#
vec3 EmitterVelocity#
vec3 EmitterSpread#
vec3 EmitterDirection#
vec3 EmitterSize#
- OBJECT_PARTICLES_EMITTER_POINT, OBJECT_PARTICLES_EMITTER_RANDOM or OBJECT_PARTICLES_EMITTER_SPARK: all vector components are ignored.
- OBJECT_PARTICLES_EMITTER_SPHERE: the first vector component is the radius of the sphere.
- OBJECT_PARTICLES_EMITTER_CYLINDER: the first vector component is the radius of the cylinder, the second vector component is the height of the cylinder.
- OBJECT_PARTICLES_EMITTER_BOX: all vector components are interpreted as box dimensions (x, y, z).
int EmitterSync#
int EmitterLimit#
int EmitterSequence#
bool IsEmitterContinuous#
bool IsEmitterShift#
bool IsEmitterBased#
bool IsEmitterEnabled#
int ProceduralParenting#
- 0 - a decal/field node that uses the procedural texture is a child of the particle system.
- 1 - a decal/field node that uses the procedural texture is a parent of the particle system.
int ProceduralPositioning#
- Positioning mode can be set only when the particle system is a parent of a decal/field node that uses the procedural texture (parenting mode is set to 0)
- Procedural rendering must be enabled.
- PROCEDURAL_POSITIONING_MANUAL = 0 - position of a child decal/field node, that uses the procedural texture, can be changed manually.
- PROCEDURAL_POSITIONING_AUTO = 1 - position of a child decal/field node, that uses the procedural texture, is automatically defined by the position of particle system and cannot be changed manually.
bool IsProceduralRendering#
int EmitterType#
float Roughness#
float Restitution#
float GrowthDamping#
float AngularDamping#
float LinearDamping#
float LengthFlattening#
float LengthStretch#
float PhysicalMass#
int PhysicalMask#
int NumParticles#
float SpawnThreshold#
float SpawnScale#
float SpawnRate#
int NumberPerSpawn#
bool IsClearOnEnable#
int Culling#
int Collision#
int Intersection#
int TextureAtlas#
int VariationY#
int VariationX#
int DepthSort#
float MaxWarmingTime#
int Warming#
int ParticlesType#
uint Seed#
Members
static ObjectParticles ( ) #
Constructor. Creates a particle system.static ObjectParticles Cast ( Node node ) #
Casts an ObjectParticles out of the Node instance.Arguments
- Node node - Node instance.
Return value
ObjectParticles instance.static ObjectParticles Cast ( Object base ) #
Casts an ObjectParticles out of the Object instance.Arguments
- Object base - Object instance.
Return value
ObjectParticles instance.void SetAngle ( float mean, float spread ) #
Sets an angle of emission.Arguments
- float mean - Mean value in degrees.
- float spread - Spread value in degrees.
float GetAngleMean ( ) #
Returns the mean value of the emission angle.Return value
The mean value in degrees.float GetAngleSpread ( ) #
Returns the spread value of the emission angle.Return value
The spread value in degrees.vec3 GetContactNormal ( int num ) #
Returns the point of the particles collision with other objects.Arguments
- int num - The collision point number.
Return value
Collision point coordinates.Object GetContactObject ( int num ) #
Returns the object that collided with particles collided in a given collision point.Arguments
Return value
The object participated in collision.Vec3 GetContactPoint ( int num ) #
Returns the normal vector for the collision point of the particles with other objects.Arguments
Return value
Normal vector coordinates.vec3 GetContactVelocity ( int num ) #
Returns the velocity in the collision point of the particles with other objects.Arguments
Return value
Velocity values for each of space dimensions.void SetDeflectorAttached ( int num, int attached ) #
Attaches or detaches a given deflector to the particle system.Arguments
- int num - The deflector number.
- int attached - 1 to attach the deflector, 0 to detach it.
int IsDeflectorAttached ( int num ) #
Returns a value indicating if a given deflector is attached to the particle system.Arguments
- int num - Number of the deflector.
Return value
1 if the deflector is attached; otherwise, 0.void SetDeflectorEnabled ( int num, bool enabled ) #
Enables or disables the given deflector.Arguments
- bool enabled - 1 to enable the deflector, 0 to disable it.
int IsDeflectorEnabled ( int num ) #
Returns a value indicating if the given deflector is enabled.Arguments
Return value
1 if the deflector is enabled; otherwise, 0.void SetDeflectorRestitution ( int num, float restitution ) #
Sets restitution of the deflector. Makes sense only for reflectors.Arguments
- float restitution - A new restitution. The provided value will be saturated in the range [0; 1].
float GetDeflectorRestitution ( int num ) #
Returns the current restitution of the deflector. Makes sense only for reflectors.Arguments
Return value
The current restitution.void SetDeflectorRoughness ( int num, float roughness ) #
Sets roughness of the deflector surface. Makes sense only for reflectors.Arguments
- float roughness - A new roughness. The provided value will be saturated in the range [0; 1].
float GetDeflectorRoughness ( int num ) #
Returns the current roughness of the deflector. Makes sense only for reflectors.Arguments
Return value
The current roughness.void SetDeflectorSize ( int num, vec3 size ) #
Sets dimensions of a given deflector.Arguments
- vec3 size - New dimensions. Only the first two components are taken into account (x and y).
vec3 GetDeflectorSize ( int num ) #
Returns the current dimensions of the given deflector.Arguments
Return value
The current dimensions. Only the first two components should be taken into account (x and y).void SetDeflectorTransform ( int num, Mat4 transform ) #
Sets a transformation matrix for a given deflector. This matrix describes the position and orientation of the deflector.Arguments
- Mat4 transform - A new transformation matrix.
Mat4 GetDeflectorTransform ( int num ) #
Returns the transformation matrix of a given deflector. This matrix describes the position and orientation of the deflector. The default is the identity matrix.Arguments
Return value
The transformation matrix.void SetDeflectorType ( int num, int type ) #
Sets a type of a given deflector.Arguments
- int type - OBJECT_PARTICLES_DEFLECTOR_REFLECTOR or OBJECT_PARTICLES_DEFLECTOR_CLIPPER.
int GetDeflectorType ( int num ) #
Returns a type of a given deflector.Arguments
Return value
DEFLECTOR_REFLECTOR or DEFLECTOR_CLIPPER.void SetDelay ( float mean, float spread ) #
Sets delay of particle system initialization relative to the parent particle one.Arguments
- float mean - A mean value in seconds. If a negative value is provided, 0 will be used instead.
- float spread - A spread value in seconds.
float GetDelayMean ( ) #
Returns the mean value of particles initialization delay relative to the parent particle system.Return value
The mean value in seconds.float GetDelaySpread ( ) #
Returns the spread value of particles initialization delay relative to the parent particle system.Return value
The spread value in seconds.void SetDuration ( float mean, float spread ) #
Sets a duration of each particle emission in seconds.Arguments
- float mean - Mean value in seconds. If a negative value is provided, 0 will be used instead.
- float spread - Spread value in seconds.
float GetDurationMean ( ) #
Returns the current mean value of particle emission intervals.Return value
The mean value in seconds.float GetDurationSpread ( ) #
Returns the current spread value of particle emission intervals.Return value
The spread value in seconds.void SetForceAttached ( int num, int attached ) #
Attaches or detaches the given force to the particle system.Arguments
- int num - Number of the force.
- int attached - 1 to attach the force, 0 to detach it.
int IsForceAttached ( int num ) #
Returns a value indicating if the given force is attached to the particle system.Arguments
Return value
1 if the force is attached; otherwise, 0.void SetForceAttenuation ( int num, float attenuation ) #
Sets an attenuation factor for the specified force.Arguments
- int num - The force number.
- float attenuation - An attenuation factor.
float GetForceAttenuation ( int num ) #
Returns the current attenuation factor for the specified force.Arguments
Return value
The current attenuation factor.void SetForceAttractor ( int num, float attractor ) #
Sets the attraction force that will be applied to the particles in the specified force radius.Arguments
- int num - The attraction force number.
- float attractor - The force value.
float GetForceAttractor ( int num ) #
Returns the current attraction force applied to the particles in the specified force radius.Arguments
Return value
The force value.void SetForceEnabled ( int num, bool enabled ) #
Enables or disables the given force.Arguments
- bool enabled - 1 to enable the force, 0 to disable it.
int IsForceEnabled ( int num ) #
Returns a value indicating if the given force is enabled.Arguments
Return value
1 if the force is enabled; otherwise, 0.void SetForceRadius ( int num, float radius ) #
Sets a radius for applying the force.Arguments
- float radius - A radius in units. If a negative value is provided, 0 will be used instead.
float GetForceRadius ( int num ) #
Returns the current radius set for applying the force.Arguments
Return value
The current radius in units.void SetForceRotator ( int num, float rotator ) #
Sets a rotation force that will be applied to the particles in the specified force radius.Arguments
- int num - The rotation force number.
- float rotator - The force value.
float GetForceRotator ( int num ) #
Returns the current rotation force applied to the particles in the specified force radius.Arguments
Return value
The force value.void SetForceTransform ( int num, Mat4 transform ) #
Sets a transformation matrix for the specified force.Arguments
- Mat4 transform - A transformation matrix.
Mat4 GetForceTransform ( int num ) #
Returns the current transformation matrix for the specified force.Arguments
Return value
The transformation matrix.void SetGrowth ( float mean, float spread ) #
Sets a particle growth factor.Arguments
- float mean - A mean value.
- float spread - A spread value.
float GetGrowthMean ( ) #
Returns the current mean value of the particle growth factor.Return value
The mean value.float GetGrowthSpread ( ) #
Returns the current spread value of the particle growth factor.Return value
The spread value.void SetLife ( float mean, float spread ) #
Sets a lifetime duration of particles in seconds.Arguments
- float mean - A mean value in seconds. If a too small value is provided, 1E-6 will be used instead.
float GetLifeMean ( ) #
Returns the current mean value of particle lifetime duration.Return value
The mean value in seconds.float GetLifeSpread ( ) #
Returns the current spread value of particle lifetime duration.Return value
The spread value in seconds.void SetNoiseAttached ( int num, int attached ) #
Sets the noise as an attached.Arguments
- int num - The target noise number.
- int attached - 1 to enable the Attached flag, 0 to disable it.
int IsNoiseAttached ( int num ) #
Returns a value indicating if the given noise is attached to the particle system.Arguments
Return value
1 if the noise is attached; otherwise, 0.void SetNoiseEnabled ( int num, bool enabled ) #
Enables or disables the given noise.Arguments
- bool enabled - 1 to enable the noise, 0 to disable it.
int IsNoiseEnabled ( int num ) #
Returns a value indicating if the given noise is enabled.Arguments
Return value
1 if the noise is enabled; otherwise, 0.void SetNoiseForce ( int num, float force ) #
Sets the Force parameter value for the required noise.Arguments
- float force - The noise force value.
float GetNoiseForce ( int num ) #
Returns the Force parameter value for the required noise.Arguments
Return value
The noise force value.void SetNoiseFrequency ( int num, int frequency ) #
Sets the Frequency parameter value for the required noise.Arguments
- int frequency - The noise frequency value.
int GetNoiseFrequency ( int num ) #
Returns the Frequency parameter value for the required noise.Arguments
- int num - Target noise number.
Return value
The noise frequency value.Image GetNoiseImage ( int num ) #
Returns the spatial texture for the required noise.Arguments
Return value
The texture of the noise.void SetNoiseOffset ( int num, vec3 offset ) #
Sets the Offset parameter coordinates values for the required noise.Arguments
- vec3 offset - Offset coordinates values.
vec3 GetNoiseOffset ( int num ) #
Returns the Offset parameter coordinates values for the required noise.Arguments
Return value
Offset coordinates values.void SetNoiseScale ( int num, float scale ) #
Sets the Scale parameter value for the required noise.Arguments
- float scale - The noise scale value.
float GetNoiseScale ( int num ) #
Returns the Scale parameter value for the required noise.Arguments
Return value
The noise scale value.void SetNoiseSize ( int num, int size ) #
Sets the Size parameter value for the required noise.Arguments
- int size - Noise size value.
int GetNoiseSize ( int num ) #
Returns the Size parameter value for the required noise.Arguments
Return value
The noise size value.void SetNoiseStep ( int num, vec3 step ) #
Sets the Step parameter coordinates values for the required noise.Arguments
- vec3 step - Step coordinates values.
vec3 GetNoiseStep ( int num ) #
Returns the Step parameter coordinates values for the required noise.Arguments
Return value
Step coordinates values.void SetNoiseTransform ( int num, Mat4 transform ) #
Sets the transformation matrix for the required noise.Arguments
- Mat4 transform - The noise transformation matrix.
Mat4 GetNoiseTransform ( int num ) #
Returns the transformation matrix for the required noise.Arguments
Return value
The noise transformation matrix.Vec3 GetParticlePosition ( int num ) #
Returns the position of a given particle.Arguments
- int num - The particle number.
Return value
Position coordinates for the particle.float GetParticleRadius ( int num ) #
Returns the radius of a given particle.Arguments
Return value
Radius of the particle.void SetParticlesRotation ( float mean, float spread ) #
Sets the particle system rotation mean and spread values.Arguments
- float mean
- float spread
float GetParticlesRotationMean ( ) #
Returns the particle system rotation mean value.Return value
Rotation mean value.float GetParticlesRotationSpread ( ) #
Returns the particle system rotation spread value.Return value
Rotation spread value.void GetParticleTransforms ( Mat4[] transforms ) #
Returns transformation matrices for spawned particles.Arguments
- Mat4[] transforms - Array to which the transformation matrices will be added.
vec3 GetParticleVelocity ( int num ) #
Returns the velocity vector for a specified particle.Arguments
Return value
The velocity vector.void SetPeriod ( float mean, float spread ) #
Sets an interval of emitter inactivity in seconds.Arguments
float GetPeriodMean ( ) #
Returns the current mean value of emitter inactivity intervals.Return value
The mean value in seconds.float GetPeriodSpread ( ) #
Returns the current spread value of emitter inactivity intervals.Return value
The spread value in seconds.void SetProceduralTextureResolution ( vec3 res ) #
Sets the resolution of the procedural texture.Arguments
- vec3 res - Resolution of the texture.
vec3 GetProceduralTextureResolution ( ) #
Returns the resolution of the procedural texture.Return value
Resolution of the texture.void SetRadius ( float mean, float spread ) #
Sets a particle radius in units.Arguments
- float mean - A mean value in units. If a too small value is provided, 1E-6 will be used instead.
- float spread - A spread value in units.
float GetRadiusMean ( ) #
Returns the current mean value of particle radii.Return value
The mean value in units.float GetRadiusSpread ( ) #
Returns the current spread value of particle radii.Return value
The spread value in units.void SetVelocity ( float mean, float spread ) #
Sets an initial particle velocity in units per second.Arguments
- float mean - A mean value in units per second.
- float spread - A spread value in units per second.
float GetVelocityMean ( ) #
Returns the current mean value of the initial particle velocities.Return value
The mean value in units per second.float GetVelocitySpread ( ) #
Returns the current spread value of the initial particle velocities.Return value
The spread value in units per second.int AddDeflector ( ) #
Adds a deflector with default settings.Return value
The number of the new deflector in the list of deflectors.void AddEmitterSpark ( Vec3 point, vec3 normal, vec3 velocity ) #
Adds a spark emitter in the given point.Arguments
- Vec3 point - Point for sparks emission.
- vec3 normal - Normal of the point of spark emission.
- vec3 velocity - Velocity in the point of spark emission (velocity of source particles or node by contact).
int AddForce ( ) #
Adds a force with default settings.Return value
The number of the new force in the list of forces.int AddNoise ( ) #
Adds a new noise with default settings.Return value
The number of the new noise in the list of noises.void ClearParticles ( ) #
Deletes all particles spawned by the emitter.void RemoveDeflector ( int num ) #
Removes a given point deflector.Arguments
- int num - Number of the deflector to remove.
void RemoveForce ( int num ) #
Removes the given force.Arguments
- int num - The number of the force to remove.
void RemoveNoise ( int num ) #
Removes the given noise.Arguments
static int type ( ) #
Returns the type of the object.Return value
Object Particles type identifier.int RestoreStateSelf ( Stream stream ) #
Restores the object's state from the stream.Arguments
- Stream stream - Stream instance.
Return value
Returns 1 if the object state was successfully restored; otherwise, 0.int SaveStateSelf ( Stream stream ) #
Saves the object's state to the stream.Arguments
Return value
Returns 1 if the object state was successfully saved; otherwise, 0 is returned.int SaveStateForces ( Stream stream ) #
Saves the state of the object's forces to the specified stream.Arguments
int RestoreStateForces ( Stream stream ) #
Restores the state of the object's forces from the specified stream.Arguments
int SaveStateNoises ( Stream stream ) #
Saves the state of the object's noises to the specified stream.Arguments
int RestoreStateNoises ( Stream stream ) #
Restores the state of the object's noises from the specified stream.Arguments
int SaveStateDeflectors ( Stream stream ) #
Saves the state of the object's deflectors to the specified stream.Arguments
int RestoreStateDeflectors ( Stream stream ) #
Restores the state of the object's deflectors from the specified stream.Arguments
