Global Terrain
Global terrain is a virtually limitless terrain representing a certain fragment of Earth's surface generated on the basis of GIS data. This means that appearance of the global terrain object is determined by the accuracy and availability of geospatial data. It should be noted that there are areas of Earth's surface with only low-resolution data available or even no geospatial data at all.
This type of terrain can be successfully used for flight simulators: most of the time the plane remains at a very high altitude and low-resolution data is sufficient. High-resolution data is necessary only around landing and take-off areas.
  • There can be only one Global Terrain object on the scene.
  • Memory consumption increases significantly when several viewports are used.
To simulate overhangs and caves use static meshes.
Terrain Structure
Global terrain is represented by the following data layers:
  • Height data generated on the basis of GIS elevation data.
  • Albedo data generated on the basis of GIS satellite imagery data.
  • Normal data generated on the basis of height data.
Tiling
Global terrain has a regular grid and is represented as a tileset. Each tile has a fixed size of 128 x 128 pixels. The number of tiles in each dimension (X and Y) is determined by the area size and GIS data resolution. The higher the resolution the more tiles will be generated for the corresponding tileset.
E.g. suppose we have a height data texture with the resolution of 100 meters per pixel for an area of 50 square kilometers. Thus, we need (50000/100) x (50000/100) = 500 x 500 pixels which can be covered by 4 x 4 tiles.
The maximum number of tiles for each of the data layers is limited to 16384.
The tiles around the viewpoint are loaded automatically according to visible distance. Visible tiles change as the viewpoint moves along the terrain.
Changing visible tiles while moving the viewpoint.
LODs
A level of detail (LOD) system automatically adapts the available resolution of terrain grid according to the distance and loads corresponding tiles.
Every particular data layer has its own number of LODs. Each LOD of a particular data layer is represented by a separate tileset and has a number of parameters according to data layer type. Each LOD has its own resolution (in meters per pixel) which determines the size of its tileset.
The maximum number of LODs for each of the data layers is limited to 32.
LODs are loaded and and cleared in accordance with corresponding distances specified in the TerrainGlobal tab. These distances are be used to avoid delays and provide smoothness when switching between LODs as well as to ensure efficient memory use.
Resolution and visible distance together determine the number of tiles to be loaded around the viewpoint.
Blending of LODs
As it was mentioned, there might be no data available for a more detailed LOD of a certain area. In this case the values of the two adjacent LODs are blended together to provide a smooth look without sharp edges or black holes. Blending is performed by means of linear interpolation on the basis of masks generated by the Landscape Tool for a certain tile.
Masks are generated only for those tiles that contain the border between areas with different resolution.
Let us consider the following example. Suppose we have two LODs:
  • LOD1 with the resolution of 100 meters per pixel - green area.
  • LOD0 with the resolution of 30 meters per pixel - orange area.
In this case masks will be generated only for the tiles marked with M.
Creating a Global Terrain
You can only create a global terrain object using a Landscape Tool. To do it via UnigineEditor perform the following actions:
  1. Run UnigineEditor.
  2. Set the distance to the camera far clipping plane to at least 100 km (100000 units). The recommended value is 400 km.
  3. In the Rendering Settings window (Alt+R) -> Environment tab set the same value for the haze maximum distance as you set for the camera far distance.
  4. On the Menu bar, click Windows -> Landscape .
  5. In the Landscape Tool window that opens, do the following:
  6. Right-click on Elevation in the Data Sources section, select Add New... and specify a path to a file with GIS elevation data in the following window.
  7. Right-click on Imagery in the Data Sources section, select Add New... and specify a path to a file with GIS imagery data in the following window.
  8. Select Play area in the Output Settings section.
  9. Using a global map in the middle of the window move the bounding rectangle to the area that contains specified GIS data.
  10. Specify Play area size so, that it would cover the area with specified GIS data.
  11. Select Quality in the Output Settings section. You will see autogenerated LODs for the specified GIS data with visible distance and density.
  12. Specify the desired Max visibility distance.
  13. Select Files in the Output Settings section and specify an Output path to store generated terrain data.
  14. Save your settings in an asset using the main menu File - > Save Asset and click Generate button.
  15. Upon completion of generation process a new GlobalTerrain object will be placed on the scene.
Terrain Parameters
Global terrain parameters can be adjusted via the TerrainGlobal tab of the Nodes window. Each data layer contains a list of LODs with corresponding parameters.
Height Data
Parameters of a certain LOD of the height data layer can be accessed via the Height tab of the TerrainGlobal tab of the Nodes window.
TerrainGlobal parameters, Height tab.
  • Enabled - enable or disable the current height LOD.
  • Intersectable - enable or disable intersection detection for the current height LOD.
  • Collidable - enable or disable collision detection for the current height LOD.
  • Viewport - viewport mask for the current height LOD.
  • Intersection - intersection mask for the current height LOD.
  • Collision - collision mask for the current height LOD.
  • Path - path to a folder, in which the current height LOD is stored.
  • Visible distance - the distance starting from which the tiles of the current height LOD become visible.
  • Load distance - the distance starting from which the tiles of the current height LOD are loaded into memory.
  • Clear distance - the distance starting from which the tiles of the current height LOD are removed from memory.
  • Video memory usage - memory consumption of the current height LOD.
Albedo Data
Parameters of a certain LOD of the albedo data layer can be accessed via the Albedo tab of the TerrainGlobal tab of the Nodes window.
TerrainGlobal parameters, Albedo tab.
  • Enabled - enable or disable the current albedo LOD.
  • Viewport - viewport mask for the current albedo LOD.
  • Path - path to a folder, in which the current albedo LOD is stored.
  • Visible distance - the distance starting from which the tiles of the current albedo LOD become visible.
  • Load distance - the distance starting from which the tiles of the current albedo LOD are loaded into memory.
  • Clear distance - the distance starting from which the tiles of the current albedo LOD are removed from memory.
  • Video memory usage - memory consumption of the current albedo LOD.
Normal Data
Parameters of a certain LOD of the normal data layer can be accessed via the Normal tab of the TerrainGlobal tab of the Nodes window.
TerrainGlobal parameters, Normal tab.
  • Enabled - enable or disable the current normal LOD.
  • Viewport - viewport mask for the current normal LOD.
  • Path - path to a folder, in which the current normal LOD is stored.
  • Visible distance - the distance starting from which the tiles of the current normal LOD become visible.
  • Load distance - the distance starting from which the tiles of the current normal LOD are loaded into memory.
  • Clear distance - the distance starting from which the tiles of the current normal LOD are removed from memory.
  • Video memory usage - memory consumption of the current normal LOD.
Terrain Data Storage Format
Generated terrain data is stored in the specified folder with the following structure:
Both packed (UNG) and uncompressed terrain data storage types are supported. In the first case all tile_xx_yy.dds and mask_xx_yy.dds files are packed into a tiles.ung package.
  • heights
    • lod0
      • lod0.meta - meta information about a terrain LOD: number of tiles along axes (X and Y) and resolution (m/pixel).
      • tile_xx_yy.dds - height texture for a tile [xx, yy].
      • tiles.dds - tileset layout texture of the LOD.
      • mask_xx_yy.dds - mask texture for a tile [xx, yy].
      • masks.dds - mask layout texture of the LOD.
  • imagery
    • lod0
      • tile_xx_yy.dds - albedo texture for a tile [xx, yy].
  • normals
    • lod0
      • tile_xx_yy.dds - normal texture for a tile [xx, yy].
Global Terrain Physics Simulation
The terrain takes part in physics simulation if it has a standard surface_base property assigned. Collisions with physical bodies use the most detailed LOD 0 and are handled within a set distance, where simulation of physics is in effect.
Physical interaction can also be enabled for each of the height LODs by setting collision and intersection flags and masks.
