Unigine::NodeReference Class
Header:#include <UnigineNodes.h>
Inherits:Node
A node reference is a node that refers to an external .node file on the disk, which is obtained by exporting a node from the world.
The world can contain several instances of node references referring to the same .node file.
The .node file usually contains a pre-fabricated node (or a hierarchy of nodes) with all the materials and properties libraries that are required for its rendering. All changes that are made for the node reference via UnigineEditor are saved into this file.
The node reference should be used instead of the node if there a lot of identical objects repeated in the world: it will enable to avoid manual editing each object if you need to make the same changes in all of these objects.
Unlike regular nodes, reference nodes are loaded into the world faster because of the internal cache usage.
A bounding box of the reference node is equal to the bounding box of its root node (child nodes are disregarded).
  • Article on Nodes that lists the main differences between the regular nodes and reference nodes
  • Article on Node Reference
NodeReference Class
Members
static NodeReferencePtr create(const char * name)
Constructor. Creates a new object that references a node from a given file.
Arguments
  • const char * name - Path to a *.node file.
Ptr<NodeReference> cast(const Ptr<Node> & node)
Casts a NodeReference out of the Node instance.
Arguments
  • const Ptr<Node> & node - Pointer to Node.
Return value
Pointer to NodeReference.
int setNodeName(const char * name)
Sets a reference to a new *.node file
Arguments
Return value
Returns 1 if the new reference is set successfully; otherwise, 0.
const char * getNodeName()
Returns the path to the referenced *.node file.
Return value
Path to the referenced *.node file.
Ptr<Node> getReference()
Returns the node stored by the reference.
Return value
Node instance.
Ptr<Node> detachReference()
Releases the internal node of ownership so it is no longer owned by the node reference (made orphan). After being released the node should be appended to one of the scripts not to cause a memory leak.
To remove the node do the following:
new_node_reference = NodeReference::create(new_node);
new_node = new_node_reference->detachReference();
new_node = new_node_reference->grab();
new_node_reference.destroy();
Return value
Root node of the internal hierarchy.
int type()
Returns the type of the node.
Return value
NodeReference type identifier.
