This example shows how to customize mouse cursor appearance and change default mouse behavior in your application. It will help you to solve the following tasks:
- Changing the default mouse cursor image
- Toggling mouse cursor's visibility
- Restricting mouse cursor movement to application window's area
Defining Mouse Behavior#
- Grab - the mouse is grabbed when clicked (the cursor disappears and camera movement is controlled by the mouse). This mode is set by default.
- Soft - the mouse cursor disappears after being idle for a short time period.
- User - the mouse is not handled by the system (allows input handling by some custom module).
- In the Editor, by selecting the corresponding option in the Controls Settings.
- Via code by adding the corresponding line to the logic (world or system logic, components, expressions, etc.).
ControlsApp::setMouseHandle(Input::MOUSE_HANDLE_SOFT);
//or
ControlsApp::setMouseHandle(Input::MOUSE_HANDLE_USER);
Customizing Mouse Cursor#
You can change the look of the mouse cursor in your application using any square RGBA8 image you want. This can be done by simply adding the following lines to your code (e.g. world's init() method):
ImagePtr mouse_cursor = Image::create("textures/cursor.png");
mouse_cursor->resize(mouse_cursor->getWidth(), mouse_cursor->getWidth());
if (mouse_cursor->isLoaded() && mouse_cursor->getFormat() == Image::FORMAT_RGBA8)
App::setMouseCursor(mouse_cursor->getPixels(), mouse_cursor->getWidth());
App::setMouseShow(1);
// clearing pointer
mouse_cursor.clear();
Example Code#
- Sets a custom icon and title for the application window
- Sets a custom mouse cursor
- Switches between the following two mouse control modes by the ENTER key:
- Camera control - the cursor is invisible and controls the camera (movement area restricted to the application window)
- UI control - the cursor is visible and can be used to interact with application UI (movement area unrestricted)
- Switches between restricted (only application window area) and unrestricted mouse movement mode by the SHIFT key
// AppWorldLogic.cpp
#include "UnigineApp.h"
#include "UnigineUserInterface.h"
#include "UnigineGui.h"
#include "UnigineGame.h"
// auxiliary variables
ControlsPtr controls;
GuiPtr gui;
// widgets
WidgetLabelPtr label;
WidgetButtonPtr button;
/// function toggling the mouse cursor's state
void ToggleMouseCursor()
// getting current mouse state
int enabled = ControlsApp::isMouseEnabled();
// toggling movement restriction to the application window area
App::setMouseGrab(1 - enabled);
// toggling mouse interaction with GUI elements
gui->setMouseEnabled(enabled);
// toggling mouse control
ControlsApp::setMouseEnabled(1 - enabled);
int AppWorldLogic::init()
// enabling user mouse handling
gui = Gui::get();
ImagePtr icon = Image::create("textures/cursor.png");
if (icon->isLoaded() && icon->getFormat() == Image::FORMAT_RGBA8)
App::setIcon(icon->getPixels2D(), icon->getWidth());
icon.clear();
App::setTitle("Custom Window Title");
// preparing UI: creating a label and a button and adding them to the GUI
label = WidgetLabel::create(gui);
button = WidgetButton::create(gui, "BUTTON");
button->setPosition(10, 40);
gui->addChild(label, Gui::ALIGN_OVERLAP | Gui::ALIGN_TOP | Gui::ALIGN_LEFT);
gui->addChild(button, Gui::ALIGN_OVERLAP | Gui::ALIGN_TOP | Gui::ALIGN_LEFT);
// clearing pointer
int AppWorldLogic::update()
// checking for STATE_USE (ENTER key by default) and toggling mouse cursor state "hidden restricted camera control" <-> "visible unrestricted UI control"
if (controls->clearState(Controls::STATE_USE) == 1)
ToggleMouseCursor();
// checking for STATE_RUN (SHIFT key by default) and toggling mouse cursor movement restriction to application window bounds
if (controls->clearState(Controls::STATE_RUN) == 1)
App::setMouseGrab(!App::getMouseGrab());
// updating cursor position info
label->setText(String::format("\n MOUSE COORDS: %d, %d)", App::getMouseX(), App::getMouseY()));
// showing or hiding mouse cursor depending on its current state
App::setMouseShow(!ControlsApp::isMouseEnabled());
int AppWorldLogic::shutdown()
//removing all widgets grom GUI
for (int i = 0; i < gui->getNumChildren(); i++)
gui->removeChild(gui->getChild(i));
// clearing pointers
controls.clear();
button.clear();
label.clear();
gui.clear();
