gpu_monitor_00
This article describes the <UnigineSDK>/data/samples/plugins/gpu_monitor_00.cpp sample.
The gpu_monitor_00 sample demonstrates how to get and display the GPU frequencies and temperature by using the GPUMonitor plugin.
It is required to launch the GPUMonitor plugin before running the sample.
GPU Monitor plugin
Last update: 2020-04-10
