billboards_03
This article describes the data/samples/objects/billboards_03.cpp sample.
The billboards_03 sample demonstrates how to create a starry night sky by using the Billboards object of the ObjectBillboards class.
The following information about the Billboards object is loaded from the data/samples/objects/billboards/billboards_03.node file:
- Number of generated billboards
- Material and property assigned to the billboards
- Transformation of the billboards
- Options of the Billboards Generator
Stars created with the billboards_03.cpp script
- Article on Billboards
- Article on Stars Generator for Billboards
- Functions of the ObjectBillboards class
