billboards_03
This article describes the data/samples/objects/billboards_03.cpp sample.
The billboards_03 sample demonstrates how to create a starry night sky by using the Billboards object of the ObjectBillboards class.
The following information about the Billboards object is loaded from the data/samples/objects/billboards/billboards_03.node file:
Stars created with the billboards_03.cpp script
Last update: 2020-04-10
