billboards_02
This article describes the data/samples/objects/billboards_02.cpp sample.
The billboards_02 sample demonstrates how to:
  • Create several billboards with the same material by using the ObjectBillboards
  • Add the ObjectBillboards object to the editor
  • Set texture coordinates for each billboard baked into the ObjectBillboards object
Billboards created by using the billboards_02.cpp script
Last update: 2020-04-10
