Volume Box
Volume box is a cuboid shaped volume that can be used to simulate:
  • Fog, haze or mist that hides objects behind it. If boxes with fog intersect, denser fog is created.
  • Clouds or shaped fog.
  • Light shafts from the world light source. For sun beams to fall through windows and other openings, the room should be inside the box.
Volume box with a fog material
Volume box with a fog material on the floor
Box Options
Size Length, width and height of the box (in units) along X, Y and Z axes.
Last update: 03.07.2017
