Полезные советы
Each world script is associated with a certain world. Although the basic recommended workflow when writing application logic in C++ / C# is to have a single AppWorldLogic class to process all worlds in your project, sometimes it might be necessary to split world logic between several separate classes. In such a case the basic AppWorldLogic class is used as a manager calling corresponding methods (init(), update(), postUpdate(), etc.) of a particular class implementing logic of the current world.
This example illustrates how to split world-specific code between separate classes. Suppose in our project we have a default world named "world1" and another one named "world2" and we want to have two separate world logic classes (WorldLogic1 and WorldLogic2) for each of these worlds. Suppose we also want to switch between these worlds by pressing PGUP and PGDOWN keys.
1. Creating WorldLogic Classes#
First, we just inherit two new classes (WorldLogic1 and WorldLogic2) from Unigine.WorldLogic. You can simply copy the contents of AppWorldLogic.cs file and modify their init() and update() methods like this:
You can implement your logic for other methods of the execution sequence if necessary.
WorldLogic1.cs
Source code (C#)
namespace UnigineApp
    class WorldLogic1 : WorldLogic
        public WorldLogic1()
		public override bool Init()
            Log.Message("Initializing the FIRST world ({0})\n", World.Path);
			// insert your init logic for the first world
			return true;
		public override bool Update()
			// insert your update logic for the first world
			return true;
WorldLogic2.cs
Source code (C#)
    class WorldLogic2: WorldLogic
        public WorldLogic2()
            Log.Message("Initializing the SECOND world ({0})\n", World.Path;
			// insert your init logic for the second world
			return true;
			// insert your update logic for the second world
			return true;
2. Managing World Logics via AppWorldLogic#
Now, we implement world logic management in the AppWorldLogic, so we should add all our world logics, and a pointer to the one currently used. Inside each method of the AppWorldLogic class we simply call the corresponding method of the current world logic class, like for the init() and update() methods below. In the init() method, as it is called each time a new world is loaded, we should change the current world logic. So, we modify the AppWorldLogic.cs file as follows:
AppWorldLogic.cs
Source code (C#)
using Unigine;
        public WorldLogic1 wl1;						//<-- world logic for the first world
        public WorldLogic2 wl2;						//<-- world logic for the second world
        public WorldLogic current_world_logic;		//<-- pointer to the current world logic
		public AppWorldLogic()
            // creating world logic instances and setting the first one as current
            wl1 = new WorldLogic1();
            wl2 = new WorldLogic2();
            current_world_logic = wl1;
            // checking the name of the loaded world and changing current world logic if necessary
            if (string.Compare(World.Path, "world1") == 0)
            else if (string.Compare(World.Path, "world2") == 0)
                current_world_logic = wl2;
            // calling the init() method of the current world logic
            current_world_logic.Init();
			return true;
		// start of the main loop
			// calling the update() method of the current world logic
            current_world_logic.Update();
			return true;
3. Keyboard World Loading via AppSystemLogic#
Switching between the worlds is to be performed in the AppSystemLogic class. In the update() method we should check keyboard input and load the corresponding world if necessary. So, we modify the AppSystemLogic.cs file as follows:
AppSystemLogic.cs
Source code (C#)
using Unigine;
    class AppSystemLogic : SystemLogic
            // checking key states and switching worlds
            if (App.ClearKeyState(App.KEY_PGUP) == 1)
            {   // loading the second world if it is not already loaded
                if (World.Path.EndsWith("world2.world"))
                    World.LoadWorld("world2");
            else if (App.ClearKeyState(App.KEY_PGDOWN) == 1)
            {   // loading the first world if it is not already loaded
                if (World.Path.EndsWith("world1.world"))
                    World.LoadWorld("world1");
            return true;
Now, the logic of each of our world files (world1 and world2) is controlled by the corresponding WorldLogic class.
Last update: 31.07.2020
