Playing Sounds on Collisions
The example below demonstrates how to:
- Create a new sound source.
- Update settings of the existing sound source.
- Implement a contact callback that plays a sound at a contact with a physical body.
The sound file used in the example can be found in the <UnigineSDK>/data/samples/sounds/sounds folder. You can also specify any other file, including .mp3.
AppWorldLogic.cs:
Source code (C#)
#region Math Variables
#if UNIGINE_DOUBLE
using Scalar = System.Double;
using Vec2 = Unigine.dvec2;
using Vec3 = Unigine.dvec3;
using Vec4 = Unigine.dvec4;
using Mat4 = Unigine.dmat4;
#else
using Scalar = System.Single;
using Vec2 = Unigine.vec2;
using Vec3 = Unigine.vec3;
using Vec4 = Unigine.vec4;
using Mat4 = Unigine.mat4;
using WorldBoundBox = Unigine.BoundBox;
using WorldBoundSphere = Unigine.BoundSphere;
using WorldBoundFrustum = Unigine.BoundFrustum;
#endif
#endregion
using System;
using System.Linq;
using System.Text;
using Unigine;
class UnigineApp
public struct ContactArguments
public Body body;
public int num;
public ContactArguments(Body body, int num)
this.body = body;
this.num = num;
public List<ContactArguments> callbacks = new List<ContactArguments>();
public List<SoundSource> sounds = new List<SoundSource>();
public AppWorldLogic()
public void contact_callback(Body body, int num)
callbacks.Add(new ContactArguments(body, num));
public void contact_callback_handler(Body body, int num)
if (num >= body.NumContacts)
return;
// get coordinates of the contact point
Vec3 position = new Vec3(body.GetContactPoint(num));
// get the relative impulse in the contact point
float impulse = body.GetContactImpulse(num);
// calculate volume of the sound played for the contact
float volume = impulse * 0.5f - 1.0f;
// a flag indicating that no sounds have played yet
bool need_sound = true;
for (int i = 0; i < sounds.Count; i++)
if (sounds[i].IsPlaying)
need_sound = false;
// reuse the existing sound source
sounds[i].Enabled = true;
sounds[i].Gain = MathLib.Saturate(volume);
sounds[i].WorldTransform = MathLib.Translate(position);
Sound.RenderWorld(1);
sounds[i].Play();
break;
if (need_sound)
// create a new sound source
SoundSource s = new SoundSource("static_impact_00.wav");
// specify necessary settings for the sound source
s.Occlusion = 0;
s.MinDistance = 10.0f;
s.MaxDistance = 100.0f;
s.Gain = MathLib.Saturate(volume);
s.WorldTransform = MathLib.Translate(position);
// play the sound source
s.Play();
// append the sound to the vector of the playing sounds
sounds.Add(s);
// method creating a box mesh with a physical body
public void create_box(Vec3 position)
Mesh mesh = new Mesh();
mesh.AddBoxSurface("box_0", new vec3(0.5f));
ObjectMeshStatic object_mesh = new ObjectMeshStatic(mesh);
object_mesh.WorldTransform = MathLib.Translate(position);
object_mesh.SetCollision(true, 0);
BodyRigid body = new BodyRigid(object_mesh);
new ShapeBox(body, new vec3(0.5f));
// set a callback function that is run when a contact with the box occurs
body.AddContactEnterCallback(contact_callback);
public override bool Init()
// create box meshes
for (int i = -5; i <= 5; i++)
create_box(new Vec3(0.0f, i * 2.0f, 8.0f + i * 1.0f));
// create another box mesh
create_box(new Vec3(5.0f, 10.0f, 50.0f));
sounds.Clear();
callbacks.Clear();
return true;
public override bool Update()
if (callbacks.Count > 0)
for (int i = 0; i < callbacks.Count; i++)
contact_callback_handler(callbacks[i].body, callbacks[i].num);
callbacks.Remove(callbacks[i]);
callbacks.Clear();
return true;
public override bool PostUpdate()
return true;
public override bool UpdatePhysics()
return true;
// end of the main loop
public override bool Shutdown()
foreach (var s in sounds)
sounds.Clear();
return true;
public override bool Save(Stream stream)
return true;
public override bool Restore(Stream stream)
return true;
class AppSystemLogic : SystemLogic
App.SetBackgroundUpdate(true);
Unigine.Console.Run("world_load data/sounds_collisions");
Unigine.Console.Run("show_visualizer 1");
return true;
[STAThread]
static void Main(string[] args)
// init engine
Engine.InitParameters init_params = new Engine.InitParameters();
init_params.window_title = "UNIGINE Engine: UsageExample - Playing Sounds on Collisions (C#)";
Engine.Init(init_params, args);
// enter main loop
AppSystemLogic system_logic = new AppSystemLogic();
AppWorldLogic world_logic = new AppWorldLogic();
Engine.Main(system_logic, world_logic, null);
// shutdown engine
Engine.Shutdown();
