In this example, you will learn how to stop and start the playback of all sounds on a specific channel.
Creating Sounds#
In order to control sounds in the scene, we should have them. Let's review how to add sounds.
The Sound Source object can be created in UnigineEditor as a node (let's assume we did this way in our example), while Ambient Source doesn't have any specific location and is created via code only.
In the Init() method, we create the ambient source and configure it as required.
Source code (C#)
private void Init()
	AmbientSource ambient0 = new AmbientSource("sound0.mp3");
		ambient0.SourceMask = 1;
		ambient0.Loop = 1;
		ambient0.Play();
Having all these sources at hand, we can fine-tune their behavior.
Getting Sounds#
Now we need to get sounds to control them. We'll get Sound Sources by using the method World.GetNodesByType() and add them to the vector storing all sound source nodes:
Source code (C#)
private void GetAllSoundSources(out List<SoundSource> sounds)
	List<Node> nodes = new List<Node>();
	World.GetNodesByType((int)Node.TYPE.SOUND_SOURCE, nodes);
	sounds = new List<SoundSource>();
	foreach (var n in nodes)
		sounds.Add(n as SoundSource);
We'll also declare a vector storing all ambient sounds:
Source code (C#)
private List<AmbientSource> ambientSounds = new List<AmbientSource>();
And add one more sound setting in the Init() method that will add the ambient sound to the vector:
Source code (C#)
ambientSounds.Add(ambient0);
Controlling the Playback#
We can control the playback via the SoundSource and the AmbientSource class methods Play(), Stop(), and the Time property. The general approach is to get all sound sources with the mask of the required channel enabled and then pause them using Stop(). This method doesn't reset the playback time, therefore the Play() method will resume the sound playback from the moment it has been paused.
First, we create a method that plays sounds that have the corresponding sound channel enabled.
Source code (C#)
private void PlaySourceChannel(int number, in List<SoundSource> sounds)
	foreach (var s in sounds)
		if ((s.SourceMask & (1 << number)) != 0)
			s.Play();
Then we create a method that will play both Sound Sources and Ambient Sources on the specified channel at the same time:
Source code (C#)
private void PlaySourceChannel(int number, in List<SoundSource> sources, in List<AmbientSource> ambients)
	PlaySourceChannel(number, sources);
	foreach (var a in ambients)
		if ((a.SourceMask & (1 << number)) != 0)
			a.Play();
Stopping the sound playback uses the same approach.
If a sound source plays on several channels, disabling it means that it will be disabled on all channels.
Source code (C#)
private void StopSourceChannel(int number, in List<SoundSource> sounds)
			s.Stop();
private void StopSourceChannel(int number, in List<SoundSource> sources, in List<AmbientSource> ambients)
	StopSourceChannel(number, sources);
			a.Stop();
The only thing left is to bind methods and buttons:
Source code (C#)
private void Update()
		if (Input.IsKeyDown(Input.KEY.P))
				GetAllSoundSources(out List<SoundSource> sources);
				PlaySourceChannel(0, sources, ambientSounds);
			if (Input.IsKeyDown(Input.KEY.S))
				StopSourceChannel(0, sources, ambientSounds);
Code Sample#
Here's a complete code:
You can create a C# component and add the following code to it except for the PropertyGuid value, which is generated individually for each component at its creation. Keep in mind adding audio files with the corresponding names to your project.
Source code (C#)
using System;
using System.Collections;
using Unigine;
public class GlobalSoundSourcesController : Component
	private void Init()
			ambient0.Loop = 1;
			ambient0.Play();
			AmbientSource ambient1 = new AmbientSource("sound1.mp3");
			ambient1.SourceMask = 1;
			ambient1.Loop = 1;
			ambient1.Play();
			ambientSounds.Add(ambient1);
					s.Play();
					a.Play();
					s.Stop();
					a.Stop();
Last update: 2022-04-07
