Water
Water Settings
Water Settings
SSR Enabled Enables or disables the SSR (Screen Space Reflections) effect for water.
SSR Quality Quality of the water screen-space reflections:
  • Low — low quality.
  • Medium — medium quality.
  • High — high quality.
  • Ultra — ultra quality.
SSR Increased Accuracy Enables or disables increased accuracy for the water SSR (Screen Space Reflections). This option reduces visual artifacts by increasing accuracy of the last step.
Refraction Quality Quality of water refraction.
  • Low - low quality.
  • Medium - medium quality.
  • High - high quality (by default).
  • Ultra - ultra quality.
Anisotropy Quality Water texture anisotropy level.
  • 1x - anisotropy level 1.
  • 2x - anisotropy level 2 (by default).
  • 4x - anisotropy level 4.
  • 8x - anisotropy level 8.
  • 16x - anisotropy level 16.
Shoreline Wetness Enables or disables the wetness effect for objects near the shoreline.
Render Underwater Shafts Enables or disables rendering of underwater shafts.
Render Environment Probes Enables or disables rendering of environment probes on the water surface.
Render Lights Enables or disables rendering of lights on the water surface.
Field Height Resolution This parameter determines the resolution of the texture into which all textures set for all FieldHeight objects are rendered. The following values are available:
  • 128 x 128
  • 256 x 256
  • 512 x 512 (by default)
  • 1024 x 1024
  • 2048 x 2048
  • 4096 x 4096
  • 8192 x 8192
Field Precision 32 bits Enables 32-bit precision for of textures used for field objects.
Field Shoreline Resolution This parameter determines the resolution of the texture into which all textures set for all FieldShoreline objects are rendered. The following values are available:
  • 128 x 128 (by default)
  • 256 x 256
  • 512 x 512
  • 1024 x 1024
  • 2048 x 2048
  • 4096 x 4096
  • 8192 x 8192
Last update: 2018-08-10
