Console Migration
Changed Console Commands#
UNIGINE 2.8 | UNIGINE 2.9 |
render_shadows_soft | Removed. |
render_shadows_soft_noise | Removed. |
render_shadows_soft_quality | Removed. |
render_lights_interleaved_fix_ghosting | Removed. |
render_skip_render_materials | Renamed to render_pre_post_materials_enabled. |
render_skip_post_materials | Renamed to render_screen_space_effects. |
render_skip_transparent | Renamed to render_transparent_enabled. |
render_skip_transparent_ambient | Renamed to render_transparent_ambient. |
render_skip_transparent_light | Renamed to render_transparent_light. |
render_skip_transparent_deferred | Renamed to render_transparent_deferred. |
render_skip_transparent_multiple_env_probes | Renamed to render_transparent_multiple_env_probes. |
render_skip_water | Renamed to render_water_enabled. |
render_skip_clouds | Renamed to render_clouds_enabled. |
render_skip_lights | Renamed to render_lights_enabled. |
render_sss | Renamed to render_sssss. |
render_sss_color | Renamed to render_sssss_color. |
render_sss_radius | Renamed to render_sssss_radius. |
render_sss_resolution | Renamed to render_sssss_resolution. |
render_sss_quality | Renamed to render_sssss_quality. |
render_taa_color_clamping | Renamed to render_taa_frames_by_color. |
render_taa_velocity_clamping | Renamed to render_taa_frames_by_velocity. |
render_taa_velocity_threshold | Renamed to render_taa_frames_velocity_threshold. |
render_taa_max_frame_count | Renamed to render_taa_max_frames_by_velocity. |
render_taa_min_frame_count | Renamed to render_taa_min_frames_by_velocity. |
New Console Commands#
Shadows#
Rendering#
Screen-Space Subsurface Scattering#
- render_sssss_ambient
- render_sssss_diffuse
- render_sssss_noise_ray
- render_sssss_noise_step
- render_sssss_max_threshold
- render_sssss_min_threshold
- render_sssss_interleaved
- render_sssss_interleaved_color_clamping
- render_sssss_interleaved_samples
- render_sssss_taa_fix_flicker
- render_sssss_taa_antialiasing_in_motion
- render_sssss_taa_frames_by_color
- render_sssss_taa_frames_by_velocity
- render_sssss_taa_preserve_details
- render_sssss_taa_frame_count
- render_sssss_taa_frames_velocity_threshold
- render_sssss_taa_max_frames_by_velocity
- render_sssss_taa_min_frames_by_velocity
- render_sssss_taa_pixel_offset
- render_sssss_taa_catmull_resampling
- render_sssss_taa_samples
Screen-Space Reflections#
Screen-Space Global Illumination#
Miscellaneous#
Была ли эта статья полезной?
