Each world script is associated with a certain world. Although the basic recommended workflow when writing application logic in C++ / C# is to have a single AppWorldLogic class to process all worlds in your project, sometimes it might be necessary to split world logic between several separate classes. In such a case the basic AppWorldLogic class is used as a manager calling corresponding methods (init(), update(), render(), etc.) of a particular class implementing logic of the current world.
This example illustrates how to split world-specific code between separate classes. Suppose in our project we have a default world named "world1" and another one named "world2" and we want to have two separate world logic classes (WorldLogic1 and WorldLogic2) for each of these worlds. Suppose we also want to switch between these worlds by pressing PGUP and PGDOWN keys.
1. Creating WorldLogic Classes#
First, we just inherit two new classes (WorldLogic1 and WorldLogic2) from Unigine::WorldLogic. You can simply copy the contents of AppWorldLogic.h and AppWorldLogic.cpp files and modify their init() and update() methods like this:
WorldLogic1.cpp
int WorldLogic1::init()
// reporting that we're processing the first world and displaying its name
Log::message("Initializing the FIRST world named %s.world\n", World::get()->getName());
// insert your init logic for the first world
int WorldLogic1::update()
// insert your update logic for the first world
WorldLogic2.cpp
int WorldLogic2::init()
Log::message("Initializing the SECOND world named %s.world\n", World::get()->getName());
// insert your init logic for the second world
int WorldLogic2::update()
// insert your update logic for the second world
2. Managing World Logics via AppWorldLogic#
Now, we implement world logic management in the AppWorldLogic, so we should add all our world logics, and a pointer to the one currently used. In the init() method, as it is called each time a new world is loaded, we should change the current world logic. So we modify the AppWorldLogic.h file as follows:
AppWorldLogic.h
#include "AppWorldLogic1.h" //<-- include world logic class declaration for the first world
#include "AppWorldLogic2.h" //<-- include world logic class declaration for the second world
Unigine::WorldLogic *current_world_logic = &wl1; //<-- pointer to the current world logic, we set the first one by default
AppWorldLogic1 wl1; //<-- world logic for the first world
AppWorldLogic2 wl2; //<-- world logic for the second world
Inside each method of the AppWorldLogic class we simply call the corresponding method of the current world logic class, like for the init() and update() methods below. In the init() method, as it is called each time a new world is loaded, we also should change the current world logic if necessary:
AppWorldLogic.cpp
#include <UnigineWorld.h> //<-- include the UnigineWorld.h for the World class
int AppWorldLogic::init()
// checking the name of the loaded world and updating current world logic
if (strcmp(World::get()->getName(), "world1") == 0)
else if (strcmp(World::get()->getName(), "world2") == 0)
current_world_logic = &wl2;
// calling the init() method of the current world logic
current_world_logic->init();
int AppWorldLogic::update()
// calling the update() method of the current world logic
current_world_logic->update();
3. Keyboard World Loading via AppSystemLogic#
Switching between the worlds is to be performed in the AppSystemLogic class. In the update() method we should check keyboard input and load the corresponding world if necessary. So, we modify the AppSystemLogic.cpp file as follows:
AppSystemLogic.cpp
#include <UnigineApp.h>
int AppSystemLogic::update()
// checking key states and loading worlds
if (App::get()->clearKeyState(App::KEY_PGUP))
{ // loading the second world if it is not already loaded
if (strcmp(World::get()->getName(), "world2") != 0)
World::get()->loadWorld("world2");
else if (App::get()->clearKeyState(App::KEY_PGDOWN))
{ // loading the first world if it is not already loaded
if (strcmp(World::get()->getName(), "world1") != 0)
World::get()->loadWorld("world1");
