IG Application Template
This project template is available for SIM SDK Edition only.
The Image Generator (IG) renders scenes of the virtual world, providing an immersive view of the simulation, it can be thought of as a viewport into the virtual world of simulation. A simulator may have one or more IG channels rendering an "out-the-window" view and might have several additional views representing various sensors: electro-optical (EO), infrared (IR), and night vision (NV); and sometimes radar. The way these views are displayed may vary from a simple desktop monitor to a multiple projector dome display.
The IG uses the terrain database and a set of entities (aircrafts, vehicles, etc.) to render a scene, along with sky, weather and visual effects, from the specified perspective, and sends a video signal to the appropriate display within the user interface.
The IG receives updates and events from all the other hosts from the network, be it a vehicle/aircraft simulation host, instructor operator station (IOS), physical simulation host, etc. The IG also responds to requests from other hosts to check for intersections with the terrain to determine if the vehicle/aircraft bumps into anything or has a line-of-sight to another entity(ies).
The simulator and the IG can be integrated into a single application, where the simulator uses API calls to control the IG. Or, the simulator can be connected to the IG via a network connection and communicate by sending/receiving messages specified by an interface control document such as CIGI (Common Image Generator Interface). Or, they can be connected using the distributed simulation network and pass messages using communication protocols such as DIS or HLA. Communication Protocols
HLA is a standard for interoperability among simulations. Rather than a networking protocol (wire standard) like DIS, HLA defines an architecture with a set of Application Programmer’s Interface (API) Standards. Simulation applications (known as federates) communicate by making calls to the HLA APIs. A piece of software known as the Runtime Infrastructure (RTI) implements the HLA API, and is responsible for transporting data from one federate to another.
An Entity is a static or dynamic simulation object that can be created, manipulated, and destroyed by the host. The virtual world is filled with entities, they represent certain objects of the real world (e.g. aircrafts, vehicles, ships, etc.)
A Terrain Database (or simply Database) is a virtual model of the landscape where the simulation takes place. Its character, quality, and content defines what can be done in the simulation environment. The resolution and level of detail of the terrain database content define the fidelity of interactions possible within the environment. UNIGINE supports double-precision coordinates enabling you to extend geographic coverage of the terrain, that defines the size of the area where the simulation can take place, up to the whole Earth's surface.
There’s more in a scene than the terrain database and the entities moving around – sky, atmosphere, and water. Drawing these ethereal parts of the environment is the IG’s responsibility too. Since their appearance varies dramatically depending on the weather and the time of day, several models are implemented to simulate the environment:
  • An ephemeris model determines the position of the sun and moon, which both cast light into the scene, depending on given coordinates and date/time.
  • A weather model, either in the IG or supplied by an external weather simulation, provides the cloud coverage, and a global wind concept with direction and strength, affecting vegetation animation and the environment.
UNIGINE's IG is designed to be simple, easy to use and extensible via its plug-in based architecture. The main framework plugin, that manipulates systems, entities, articulated parts, component templates and so on, is the IG Plugin, it operates in terms of the UNIGINE Engine (Nodes, NodeReferences, etc.) and is not bound to any specific communication protocol. The IG plugin has a set of additional plugins, called connectors, that are used to link IG terminology with that of each specific protocol (e.g. CIGI, HLA, DIS). Basically, the architecture looks as follows:
IG
Within the IG, all entities, lights, databases, etc. are referred to via IDs. Simple articulation of entities' parts is performed based on XML definition and does not require a modeler to prepare any animations.
UNIGINE IG is currently implemented as IG Template.
Currently supported CIGI packets
Type Supported Not Supported
ig_control Byte Swap, Database Number Timestamp, Extrapolation/Interpolation Enable, IG Mode
entity_control PARTIAL Alpha, Extrapolation/Interpolation Enable
entity_clamped_control FULL
SYMBOL_SURFACE, SYMBOL
articulated_control FULL
rate_control FULL
celestial_control FULL
atmosphere_control Visibility Range, Wind speed and direction Global Humidity, Global Air Temperature, Global Barometric Pressure
environment_control NOT SUPPORTED Merge Weather Properties, Merge Aerosol Concentrations, Merge Maritime Surface Conditions, Merge Terrestrial Surface Conditions
weather_control Layer ID (1-5), Weather Enable, Random Lightning Enable, Cloud Type (not regional clouds), Scope(0-1), Visibility Range, Coverage(for cloud), Base Elevation, Thickness, Horizontal Wind Speed, Vertical Wind Speed, Wind Direction, Aerosol Concentration (for precipitation) Entity ID, Severity, Air Temperature, Scud Frequency, Barometric Pressure
maritime_control FULL
wave_control NOT SUPPORTED
view_control FULL
sensor_control NOT SUPPORTED
tracker_control NOT SUPPORTED
earth_model_def NOT SUPPORTED
trajectory_def NOT SUPPORTED
view_def FULL
segment_def FULL
volume_def FULL
environment_request NOT SUPPORTED
symbol_surface_def PARTIAL
symbol_text_def PARTIAL
symbol_circle_def PARTIAL
symbol_line_def PARTIAL
symbol_clone NOT SUPPORTED
symbol_control PARTIAL
symbol_short_control PARTIAL
CIGI implementation currently supports synchronous operation only.
Interpolation and Extrapolation#
Unigine IG uses Interpolated Snapshots (IS) to tackle with the problem of lost packets between the IG and hosts. It works by taking two old, but known positions and interpolating the object between them. It is accomplished by having a buffer of received positions and rotations, along with the time they represent. We usually take our current local time minus some predefined amount — interpolation period (40 ms by default), then go into our buffer, find the two indices that are just before and just after this time and interpolate.
If we don't have a received position and rotation for the time we're looking for, the extrapolation (guessing) is used. It also has a limited time — extrapolation period (200 ms by default). If the extrapolation period is over but there are still no packets received, all objects will freeze.
In most cases, this method provides a very accurate representation of the world to each slave, as in general only already known positions of remote objects are rendered and in rare cases the system will try to extrapolate (guess) where an object is. This, however, comes at a cost, as we always render 40 ms (interpolation period) behind current time, so that new packets have time to arrive with data.
Using the IG Template#
    Create a Project
  2. Open the world in UnigineEditor by clicking Edit Content.
    Open the UnigineEditor
    Generate a Terrain
  5. Save your world and close Unigine Editor.
    Run the Application
    • By default your application will launch with IG, CIGIConnector plugins. If you want to change this, please modify the startup options after clicking an ellipsis under the Run button for your project on the Projects tab of the SDK Browser.
    • If you want to use a Multi-IG configuration, you should add the Syncker plugin to the startup options: -extern_plugin "Syncker" and perform steps 2 - 5 described here.
      IMPORTANT: do not add the IG Plugin on slaves, as it may result in incorrect behavior of components.
Extending Template's Functionality#
UNIGINE's IG provides the following opportunities for customization:
  • IG can be built into a Qt/WinForm/WPF application and have a custom interface (e.g., switching between cameras in the simplest case).
  • A host can have several IGs connected, and each running IG can be programmed to have its own logic, if necessary.
  • Secondary static objects (such as a billboard on a building or a ship following a certain route) can be animated, and their position, rotation, or other specific parameters can be requested via CIGI/HLA.
  • New visual effects can be created to create a more realistic picture.
  • Users can add their own custom components and process them by modifying the ig_config.xml file.
  • You can extend IG functionality to support other protocols (e.g. ALSP, TENA, CTIA, etc. ), for this purpose you'll have to write your own connectors.
Adding a Custom Connector#
A connector is actually a custom C++ Plugin used to communicate messages between the host and the IG. This plugin reads packages and calls the corresponding methods of the IG Plugin (listed in include/plugins/IGInterface.h).
Files listed below can be used as a template for your custom connector:
  • Plugin include file to be put to the include/plugins folder:
    CUSTOMConnectorInterface.h
    namespace IG
    	namespace CUSTOM
    		class ConnectorInterface
    			// client initialization
    			// client shutdown
    			virtual int shutdown() = 0;
    			// other methods
    			// callbacks
  • Plugin source files to be put to the source/custom_connector folder:
    CUSTOMConnectorPlugin.cpp
    #include <UniginePlugin.h>
    #include "CUSTOMConnector.h"
    // CUSTOMConnectorPlugin
    	CUSTOMConnectorPlugin();
    	void *get_data() override;
    	int init() override;
    	int shutdown() override;
    	void update() override;
    	: connector(nullptr)
    	delete connector;
    	return "CUSTOMConnector";
    	connector->init();
    	connector->shutdown();
    	connector->update();
    // Plugin export
    CUSTOMConnector.h
    #include <plugins/IGInterface.h>
    #include <UnigineInterface.h>
    #include <UnigineLogic.h>
    namespace IG
    namespace CUSTOM
    	class CUSTOMWorldLogic;
    		Connector();
    		virtual ~Connector() {}
    		// singleton
    		static Connector *get()
    			if (connector == nullptr)
    			return connector;
    		void init();
    		// update/shutdown client
    		void update();
    		void shutdown();
    		void onWorldInit();
    		void onWorldShutdown();
    		static Connector *connector;
    		IG::ManagerInterface *ig_manager = nullptr;
    	// WorldLogic class
    		CUSTOMWorldLogic() {}
    CUSTOMConnector.cpp
    #include <UnigineEngine.h>
    #include <UnigineNode.h>
    using namespace IG;
    using namespace CUSTOM;
    Connector::Connector() {
    void Connector::init()
    	const auto port = 3000;
    	if (ig_plugin_index == -1)
    		return;
    	ig_manager = (IG::ManagerInterface*)Engine::get()->getPluginData(ig_plugin_index);
    	// IG setup
    	ig_manager->setCoordinateSystem(IG::ManagerInterface::COORDINATE_SYSTEM::NED);
    void Connector::update()
    	// read & write packets
    void Connector::shutdown()
    	// shutdown client
    	shutdown();
    	// clear static link
    	connector = nullptr;
    void Connector::onWorldInit()
    CUSTOMConnectorInterpreter.h
    #include <UnigineBase.h>
    CUSTOMConnectorInterpreter.cpp
    using namespace IG;
    	// defines
    	// enums
    	// functions
    CUSTOMConnectorWrapper.cpp
    #ifdef __GNUC__
    #pragma GCC diagnostic push
    #elif defined(_MSC_VER)
    #pragma warning(push)
    #endif
    extern "C"
    #ifdef __GNUC__
    #pragma GCC diagnostic pop
    #pragma warning(pop)
    #endif
Last update: 16.08.2019
