API Migration
Major Changes
- Added new RenderContext class.
- Added new RenderEnvironmentPreset class.
- Added new AsyncQueue class.
- Added new TerrainGlobalDetail class.
- Added new TerrainGlobalLod class.
- Added new TerrainGlobalLods class.
- Added new TerrainGlobalLodHeight class.
- Added new UGUID class.
App Class
UNIGINE 2.5 | UNIGINE 2.6 |
initD3D11_void_void_void_int_int() | Set of arguments changed. |
initGL() | Set of arguments changed. |
New Functions
ControlsApp Class
Decal Class
Dir Class
EditorLogic Class
Ellipsoid Class
toGeodetic() | Added need_alt argument. |
Engine Class
initD3D11() | Set of arguments changed. |
New Functions
FieldHeight Class
setImageTexture() | Removed. Use setTexture() instead. |
getImageTexture() | Removed. Use getTexture() instead. |
setImageTextureImage() | Removed. Use setTextureImage() instead. |
getImageTextureImage() | Removed. Use getTextureImage() instead. |
setImageTextureName() | Removed. Use setTexturePath() instead. |
getImageTextureName() | Removed. Use getTexturePath() instead. |
New Functions
FieldShoreline Class
New Functions
FieldWeather Class
New Functions
Filesystem Class
getImage() | Removed. Use AsyncQueue::getImage() instead. |
isFile() | Set of arguments changed. |
getFileName() | Set of arguments changed. |
addKnownFile() | Set of arguments changed. |
isKnownFile() | Set of arguments changed. |
isPackageFile() | Set of arguments changed. |
getMesh() | Removed. Use AsyncQueue::getMesh() instead. |
setMTime() | Set of arguments changed. |
getMTime() | Set of arguments changed. |
getNumQueuedData() | Removed. |
getNumQueuedFiles() | Removed. Use AsyncQueue::getNumQueuedFiles() instead. |
getNumQueuedImages() | Removed. Use AsyncQueue::getNumQueuedImages() instead. |
getNumQueuedMeshes() | Removed. Use AsyncQueue::getNumQueuedMeshes() instead. |
getNumQueuedResources() | Removed. Use AsyncQueue::getNumQueuedResources() instead. |
getTotalTime() | Removed. Use AsyncQueue::getTotalTime() instead. |
checkFile() | Removed. Use AsyncQueue::checkFile() instead. |
checkImage() | Removed. Use AsyncQueue::checkImage() instead. |
checkMesh() | Removed. Use AsyncQueue::checkMesh() instead. |
forceFile() | Removed. Use AsyncQueue::forceFile() instead. |
forceImage() | Removed. Use AsyncQueue::forceImage() instead. |
forceMesh() | Removed. Use AsyncQueue::forceMesh() instead. |
loadFile() | Removed. Use AsyncQueue::loadFile() instead. |
loadImage() | Removed. Use AsyncQueue::loadImage() instead. |
loadMesh() | Removed. Use AsyncQueue::loadMesh() instead. |
removeFile() | Removed. Use AsyncQueue::removeFile() instead. |
removeImage() | Removed. Use AsyncQueue::removeImage() instead. |
removeMesh() | Removed. Use AsyncQueue::removeMesh() instead. |
validateFile() | Removed. Use isCacheFile() instead. |
getPackageFileName() | Set of arguments changed. |
New Functions
- isBlobFile()
- addBlobFile()
- removeBlobFile()
- isCacheFile()
- addCacheFile()
- removeCacheFile()
- isFile()
- isKnownFile()
- addKnownFile()
- renameKnownFile()
- renameKnownFile()
- renameKnownFile()
- renameKnownFile()
- removeKnownFile()
- removeKnownFile()
- isPackageFile()
- isPackageFile()
- isPackageFile()
- getFileName()
- getRelativeFileName()
- resolveName()
- resolveName()
- setGUID()
- getGUID()
- isGUID()
- saveGUIDs()
- loadGUIDs()
- clearGUIDs()
GeodeticPivot Class
Image Class
set2DSmooth() | Removed. |
get2DSmooth() | Removed. |
set3DSmooth() | Removed. |
New Functions
LightEnvironmentProbe Class
New Functions
LightOmni Class
New Functions
LightProj Class
New Functions
Material Class
setImageTextureFlags() | Removed. Use setTextureFlags() instead. |
getImageTextureFlags() | Removed. Use getTextureFlags() instead. |
getCompare() | Removed. |
getParameterSliderLog10() | Removed. |
loadWorld() | Removed. |
saveWorld() | Removed. |
New Functions
- isBase()
- isEngine()
- isManual()
- isInternal()
- isAutoSave()
- isNodeSupported()
- isNodeTypeSupported()
- canSave()
- canRenderNode()
- hasOverrides()
- getBaseMaterial()
- getGUID()
- setName()
- setParent()
- isParent()
- setPath()
- getPath()
- setParameter()
- getParameter()
- checkParameterConditions()
- resetParameter()
- checkStateConditions()
- resetState()
- setTexture()
- getTexture()
- checkTextureConditions()
- resetTexture()
- setTextureFlags()
- getTextureFlags()
- setTextureImage()
- getTextureImage()
- setTexturePath()
- setTexturePath()
- getTexturePath()
- getTexturePath()
- clone()
- clone()
- clone()
- inherit()
- inherit()
- inherit()
- load()
- load()
- loadXml()
- save()
- save()
- saveXml()
- reload()
- reloadShaders()
Materials Class
isLibrary() | Removed. |
isLibraryEditable() | Removed. |
getNumLibraries() | Removed. |
getNumWorldLibraries() | Removed. |
getLibraryName() | Removed. |
getWorldLibraryName() | Removed. |
addWorldLibrary() | Removed. |
findLibrary() | Removed. |
findLibraryMaterial() | Removed. |
findMaterialLibrary() | Removed. |
getNumMaterials() | Set of arguments changed. |
getMaterial() | Set of arguments changed. |
getMaterialName() | Set of arguments changed. |
cloneMaterial() | Removed. |
inheritMaterial() | Removed. |
moveMaterial() | Removed. |
removeMaterial() | Set of arguments changed. |
replaceMaterial() | Removed. |
clear() | Removed. |
create() | Removed. |
load() | Removed. |
reload() | Removed. |
save() | Removed. |
removeWorldLibrary() | Removed. |
New Functions
Node Class
canApplyToPrefab() | Removed. |
canAddChild() | Removed. |
getLinkedHierarchy() | Removed. |
getLinkedRoot() | Removed. |
isPrefabInstance() | Removed. |
isPrefabInstanceChanged() | Removed. |
isPrefabMissing() | Removed. |
setPrefabName() | Removed. |
getPrefabName() | Removed. |
getPrefabPropertyNames() | Removed. |
isPrefabPropertyOverridden() | Removed. |
freezePrefabLink() | Removed. |
hasOverridenPrefabProperties() | Removed. |
hasPrefabLink() | Removed. |
hasPrefabName() | Removed. |
revertPrefabProperty() | Removed. |
New Functions
NodeReference Class
Object Class
getSurfacePrefabPropertyNames() | Removed. |
isSurfacePrefabPropertyOverridden() | Removed. |
revertSurfacePrefabProperty() | Removed. |
New Functions
ObjectDynamic Class
ObjectExtern Class
ObjectGui Class
ObjectGuiMesh Class
ObjectMeshStatic Class
ObjectTerrainGlobal Class
setAlbedoLodClearDistance() | Removed. |
getAlbedoLodClearDistance() | Removed. |
setAlbedoLodEnabled() | Removed. |
getAlbedoLodEnabled() | Removed. |
setAlbedoLodLoadDistance() | Removed. |
getAlbedoLodLoadDistance() | Removed. |
setAlbedoLodPath() | Removed. |
getAlbedoLodPath() | Removed. |
setAlbedoLodTileDensity() | Removed. |
getAlbedoLodTileDensity() | Removed. |
getAlbedoLodTileset() | Removed. |
setAlbedoLodViewportMask() | Removed. |
getAlbedoLodViewportMask() | Removed. |
setAlbedoLodVisibleDistance() | Removed. |
getAlbedoLodVisibleDistance() | Removed. |
getAlbedoNumLods() | Removed. |
getAlbedoVideoMemoryUsage() | Removed. |
setHeightLodClearDistance() | Removed. |
getHeightLodClearDistance() | Removed. |
setHeightLodCollision() | Removed. |
getHeightLodCollision() | Removed. |
setHeightLodCollisionMask() | Removed. |
getHeightLodCollisionMask() | Removed. |
setHeightLodEnabled() | Removed. |
getHeightLodEnabled() | Removed. |
setHeightLodIntersection() | Removed. |
getHeightLodIntersection() | Removed. |
setHeightLodIntersectionMask() | Removed. |
getHeightLodIntersectionMask() | Removed. |
setHeightLodLoadDistance() | Removed. |
getHeightLodLoadDistance() | Removed. |
setHeightLodPath() | Removed. |
getHeightLodPath() | Removed. |
setHeightLodTileDensity() | Removed. |
getHeightLodTileDensity() | Removed. |
getHeightLodTileset() | Removed. |
setHeightLodViewportMask() | Removed. |
getHeightLodViewportMask() | Removed. |
setHeightLodVisibleDistance() | Removed. |
getHeightLodVisibleDistance() | Removed. |
getHeightNumLods() | Removed. |
getHeightVideoMemoryUsage() | Removed. |
setNormalLodClearDistance() | Removed. |
getNormalLodClearDistance() | Removed. |
setNormalLodEnabled() | Removed. |
getNormalLodEnabled() | Removed. |
setNormalLodLoadDistance() | Removed. |
getNormalLodLoadDistance() | Removed. |
setNormalLodPath() | Removed. |
getNormalLodPath() | Removed. |
setNormalLodTileDensity() | Removed. |
getNormalLodTileDensity() | Removed. |
getNormalLodTileset() | Removed. |
setNormalLodViewportMask() | Removed. |
getNormalLodViewportMask() | Removed. |
setNormalLodVisibleDistance() | Removed. |
getNormalLodVisibleDistance() | Removed. |
getNormalNumLods() | Removed. |
getNormalVideoMemoryUsage() | Removed. |
addAlbedoLod() | Removed. |
addHeightLod() | Removed. |
addNormalLod() | Removed. |
fetchAlbedoes() | Removed. |
fetchHeights() | Removed. |
fetchNormals() | Removed. |
removeAlbedoLod() | Removed. |
removeHeightLod() | Removed. |
removeNormalLod() | Removed. |
New Functions
- clear()
- getAlbedoLods()
- getAlbedoTextureArray()
- setAlbedoTextureArrayName()
- getAlbedoTextureArrayName()
- addDetail()
- cloneDetail()
- getDetail()
- removeDetail()
- swapDetail()
- resizeDetails()
- getNumDetails()
- addMask()
- cloneMask()
- removeMask()
- swapMask()
- resizeMasks()
- replaceMasks()
- getNumMasks()
- getMaskLods()
- setMaskName()
- getMaskName()
- getHeightLods()
- getHeightTextureArray()
- setHeightTextureArrayName()
- getHeightTextureArrayName()
- getNormalLods()
- getNormalTextureArray()
- setNormalTextureArrayName()
- getNormalTextureArrayName()
Property Class
Properties Class
Render Class
setEnvironmentAmbientIntensity() | Removed. Use setAmbientIntensity() instead. |
getEnvironmentAmbientIntensity() | Use:
setEnvironmentHazeColor() | Removed. Use setHazeColor() instead. |
getEnvironmentHazeColor() | Use:
setEnvironmentHazeDensity() | Removed. Use setHazeDensity() instead. |
getEnvironmentHazeDensity() | Use:
setEnvironmentHazeMaxDistance() | Removed. Use setHazeMaxDistance() instead. |
getEnvironmentHazeMaxDistance() | Use:
setEnvironmentPresetIntensity() | Removed. Use setIntensity() instead. |
getEnvironmentPresetIntensity() | Removed. Use getIntensity() instead. |
setEnvironmentReflectionIntensity() | Removed. Use setReflectionIntensity() instead. |
getEnvironmentReflectionIntensity() | Use:
setEnvironmentScatteringBaseLUTName() | Removed. Use setScatteringBaseLUTName() instead. |
getEnvironmentScatteringBaseLUTName() | Removed. Use getScatteringBaseLUTName() instead. |
setEnvironmentScatteringGroundColor() | Removed. Use setScatteringGroundColor() instead. |
getEnvironmentScatteringGroundColor() | Removed. Use getScatteringGroundColor() instead. |
setEnvironmentScatteringGroundLUTName() | Removed. Use setScatteringGroundLUTName() instead. |
getEnvironmentScatteringGroundLUTName() | Removed. Use getScatteringGroundLUTName() instead. |
setEnvironmentScatteringLightColorLUTName() | Removed. Use setScatteringLightColorLUTName() instead. |
getEnvironmentScatteringLightColorLUTName() | Removed. Use getScatteringLightColorLUTName() instead. |
setEnvironmentScatteringMieLUTName() | Removed. Use setScatteringMieLUTName() instead. |
getEnvironmentScatteringMieLUTName() | Removed. Use getScatteringMieLUTName() instead. |
setEnvironmentSkyIntensity() | Removed. Use setSkyIntensity() instead. |
getEnvironmentSkyIntensity() | Use:
setEnvironmentTextureColor() | Removed. Use setTextureColor() instead. |
getEnvironmentTextureColor() | Removed. Use getTextureColor() instead. |
setEnvironmentTextureName() | Removed. Use setTextureName() instead. |
getEnvironmentTextureName() | Removed. Use getTextureName() instead. |
New Functions
- setMaxFieldAnimations()
- getMaxFieldAnimations()
- setMaxFieldHeights()
- getMaxFieldHeights()
- setMaxFieldShorelines()
- getMaxFieldShorelines()
- setMaxFieldSpacers()
- getMaxFieldSpacers()
- setClearBufferMask()
- getClearBufferMask()
- setEnvironmentHazeGradient()
- getEnvironmentHazeGradient()
- getEnvironmentPreset()
Texture Class
Variable Class
Viewport Class
WidgetManipulator Class
World Class
Please be aware that the list of arguments for saveNode() and saveNodes() functions has changed the following way:
- saveNode(name, node, save_materials, binary) -> saveNode(name, node, binary)
- saveNodes(name, node, save_materials, binary) -> saveNodes(name, node, binary)
When calling these methods, you can set the binary flag to 1 by mistake, as a result you node(s) will be saved to a binary *.xml file, that cannot be read.
getAsyncNode() | Removed. Use AsyncQueue::getNode() instead. |
getAsyncNodes() | Removed. Use AsyncQueue::getNodes() instead. |
getNumQueuedNodes() | Removed. Use AsyncQueue::getNumQueuedNodes() instead. |
checkAsyncNode() | Removed. Use AsyncQueue::checkNode() instead. |
forceAsyncNode() | Removed. Use AsyncQueue::forceNode() instead. |
loadAsyncNode() | Removed. Use AsyncQueue::loadNode() instead. |
removeAsyncNode() | Removed. Use AsyncQueue::removeNode() instead. |
loadNode() | Set of arguments changed. |
saveNode() | Set of arguments changed. |
saveNodes() | Set of arguments changed. |
loadPrefab() | Removed. |
savePrefab() | Removed. |
New Functions
WorldSplineGraph Class
getNumPrefabNodes() | Removed. Use getNumSourceNodes() instead. |
addPrefabNode() | Removed. Use addSourceNode() instead. |
removePrefabNode() | Removed. Use removeSourceNode() instead. |
assignSegmentPrefab() | Removed. Use assignSegmentSource() instead. |
clearSegmentPrefab() | Removed. Use clearSegmentSource() instead. |
setPrefabForwardAxis() | Removed. Use setSourceForwardAxis() instead. |
getPrefabForwardAxis() | Removed. Use getSourceForwardAxis() instead. |
getPrefabNodeName() | Removed. Use getSourceNodeName() instead. |
getSegmentPrefabIndex() | Removed. Use getSegmentSourceIndex() instead. |
getSegmentNodes() | Set of arguments changed. |
setMaxVisibleDistance() | Removed. |
getMaxVisibleDistance() | Removed. |
setMinVisibleDistance() | Removed. |
getMinVisibleDistance() | Removed. |
New Functions
Last update: 20.10.2017
Была ли эта статья полезной?
