GPUMonitor Plugin
A GPUMonitor plugin allows monitoring the graphics card temperature and per-frame information on the chip frequency (if available).
The information provided by the plugin is displayed in the upper right corner.
GPUMonitor info
To run the plugin sample from the UNIGINE SDK Browser, go to Samples -> UnigineScript -> Plugin and run the gpu_monitor_00 sample.
GPU Information#
The following information is available for GPU:
Graphics Core clock, i.e. frequency, at which the GPU is running.
Memory Memory clock, i.e. how fast the GPU memory is running.
Processor Shader clock, i.e. how fast the shaders operate.
Temperature GPU temperature.
The table below demonstrates which information is shown for different GPUs:
GPU Graphics Memory Processor Temperature
NVIDIA
AMD
Intel not supported not supported not supported not supported
Launching GPUMonitor#
To use the plugin, check the GPU Monitor setting in UNIGINE SDK Browser on project creation and then specify the extern_plugin command line option on the start-up:
Shell commands
main_x64d -extern_plugin "GPUMonitor"
For an existing project, go to Other Actions -> Configure Project -> Video Output Options, check GPU Monitor and click Update Configuration.
To hide or show the GPUMonitor plugin information while running the application, use the show_gpu console command: pass 1 to show the information, 0 to hide it.
Last update: 10.04.2020
