UNIGINE Basics
1. Introduction
2. Managing Virtual Worlds
3. Preparing 3D Models
4. Materials
5. Cameras and Lighting
9. Physics
10. Optimization Basics
Adding a New Interactable Object
Let's add a new type of interactable object that we can grab, hold, and throw (it will be inherited from the VRBaseInteractable component) with an additional feature: some visual effect (for example, smoke) will appear when we grab the object and, it will disappear when we release the object.
  1. Create a new VRObjectVFX component and add the following code to it:
    Source code (C#)
    using System;
    using System.Collections;
    using Unigine;
    public class VRObjectVFX : VRBaseInteractable
    	// an asset with an effect that occurs when the object is grabbed
    	public AssetLinkNode vfx_node = null;
    	private Node vfx = null;
    	// this method is called for the interactable object each frame
    	private void Update()
    		// update transformation of the effect if the object is grabbed
    		if(CurrentState == VRBaseInteractable.INTERACTABLE_STATE.GRABBED)
    		vfx.WorldTransform = node.WorldTransform;
    	// this overridden method is called after component initialization (you can implement checks here)
    	protected override void OnReady()
    		// check if the asset with the visual effect is specified
    		if (vfx_node == null)
    			Log.Error($"{nameof(VRObjectVFX)} error: 'vfx_node' is not assigned.\n");
    			Enabled = false;
    			return;
    		else
    			vfx = vfx_node.Load();
    			vfx.Enabled = false;
    	// this overridden method is called when grabbing the interactable object
    	public override void OnGrabBegin(VRBaseInteraction interaction, VRBaseController controller)
    		// show the effect
    		vfx.Enabled = true;
    		// set the current object state to 'GRABBED'
    		CurrentState = VRBaseInteractable.INTERACTABLE_STATE.GRABBED;
    	// this overridden method is called when releasing the interactable object
    	public override void OnGrabEnd(VRBaseInteraction interaction, VRBaseController controller)
    		// hide the effect
    		// set the current object state to NOT_INTERACT
    		CurrentState = VRBaseInteractable.INTERACTABLE_STATE.NOT_INTERACT;
  2. Assign the VRObjectVFX component to the cylinder node (the child of the kinematic_movable dummy node).
  3. Drag the vr/particles/smoke.node asset to the Vfx Node field. This node stores the particle system representing the smoke effect. It is available in the vr/particles folder of the UNIGINE Starter Course Projects add-on.
  4. Save changes (Ctrl+S) and press the Play button to run the application.
Now, if you grab and hold the cylinder, it will generate smoke:
Last update: 2024-11-06
