UNIGINE Basics
1. Introduction
2. Managing Virtual Worlds
3. Preparing 3D Models
4. Materials
5. Cameras and Lighting
9. Physics
10. Optimization Basics
Customizing Menu
The VR template has two menu types: the main one is attached to the HMD position, and the second — to the hand. In the VR sample, the menu_attached_to_head node (ObjectGui) is used for the main menu, and the menu_attached_to_hand node (ObjectGui) is used for the additional menu.
Attached Menus
All menu nodes have the same VRMenuSample.cs component assigned. It is inherited from the base VRBaseUI component that implements a user interface. In general, the user interface is implemented as follows:
  1. Inherit a new component from the base VRBaseUI.
  2. Implement the user interface with the required widgets in the overridden InitGui() method.
  3. Implement handlers for processing widgets events (pressing a button, selecting elements in the drop-down menu, etc.).
  4. Subscribe the corresponding widgets for the events in the InitGui() method.
  5. Assign the component to the ObjectGui node that will display the user interface.
Let's create a new menu for the left controller and add the quit button:
  1. Inherit a new component from the base VRBaseUI, call it VRHandMenu and copy the following code to it:
    Source code (C#)
    using System;
    using System.Collections;
    using Unigine;
    public class VRHandMenu : VRBaseUI
    	// declare required widgets
    	private WidgetSprite background;
    	private WidgetVBox VBox;
    	private WidgetButton quitButton;
    	private WidgetWindow window;
    	private WidgetButton okButton;
    	private WidgetButton cancelButton;
    	private WidgetHBox HBox;
    	// overriden method that is called on interface initialization,
    	// it adds the required widgets and subscribes to events
    	protected override void InitGui()
    		if (gui == null)
    			return;
    		background= new WidgetSprite(gui, "core/textures/common/black.texture");
    		background.Color = new vec4(1.0f, 1.0f, 1.0f, 0.5f);
    		gui.AddChild(background, Gui.ALIGN_BACKGROUND | Gui.ALIGN_EXPAND);
    		// add a vertical column container WidgetVBox to GUI
    		VBox = new WidgetVBox();
    		VBox.Width = gui.Width;
    		VBox.Height = 100;
    		gui.AddChild(VBox, Gui.ALIGN_OVERLAP|Gui.ALIGN_CENTER);
    		// add the quit button to the container
    		quitButton = new WidgetButton(gui, "QUIT APPLICATION");
    		quitButton.FontSize = 20;
    		VBox.AddChild(quitButton);
    		quitButton.EventClicked.Connect(ButtonQuitClicked);
    		VBox.Arrange();
    		// create a quit confirmation window
    		window = new WidgetWindow(gui, "Quit Application");
    		window.FontSize = 20;
    		// add a horizontal row container WidgetHBox to the confirmation window
    		HBox = new WidgetHBox();
    		HBox.Width = window.Width;
    		HBox.Height = 100;
    		window.AddChild(HBox);
    		// add the 'OK' button and subscribe to the 'Clicked' event with the 'OkClicked' handler that will close the application
    		okButton = new WidgetButton(gui, "OK");
    		okButton.FontSize = 20;
    		HBox.AddChild(okButton);
    		okButton.EventClicked.Connect(OkClicked);
    		// add the 'Cancel' button and subscribe to the 'Clicked' event with the 'CancelClicked' handler that will close the confirmation window
    		cancelButton = new WidgetButton(gui, "Cancel");
    		cancelButton.FontSize = 20;
    		HBox.AddChild(cancelButton);
    		cancelButton.EventClicked.Connect(CancelClicked);
    	// handler to be executed on clicking 'quitButton'
    	private void ButtonQuitClicked()
    		gui.AddChild(window, Gui.ALIGN_OVERLAP | Gui.ALIGN_CENTER);
    	// handler to be executed on clicking 'cancelButton'
    	private void CancelClicked()
    		gui.RemoveChild(window);
    	// handler to be executed on clicking 'okButton'
    	private void OkClicked()
    		// quit the application
    		Engine.Quit();
  2. Then assign the VRHandMenu component to the menu_attached_to_hand node. And disable the VRMenuSample component which is assigned to this node by default.
    Hand Menu
  3. Save changes (Ctrl+S) and press the Play button to run the application.
After launching the application, press the Menu button on the left controller — the result will look similar to this:
Hand Menu Activated
Last update: 2025-06-20
