Basic Object Movements
After adding an object to UNIGINE, you can control its transformations with your control devices. This article shows how to control basic object movements and combine different transformations.
- An article on Matrix Transformations.
- An article on mat4 and dmat4 UNIGINE data types.
Direction Vector#
The direction vector is an important concept of mesh transformation. To move the node forward, you should know where the forward direction of the mesh is. When the mesh is exported from a 3D editor, it saves the information about the forward direction. And when you add the mesh to UNIGINE, it has the same orientation it had in a 3D editor.
A mesh in Maya
The same mesh in UNIGINE
In the images above, the direction vector has the positive Y direction. To move this mesh forward, you should get the direction of the mesh by using the Y component (the second column) of the world transformation matrix of the mesh.
The point is that content creators and programmers should make an arrangement about the direction vector.
Basic Movements#
Prearrangement#
We are going to make a component that allows moving and rotating an object it is assigned to. Follow these steps to prearrange the environment for using the component:
- Prepare a C#-based project.
- Open the project in the Editor.
- create a C# component.
Create the object that you are going to move, or select from the existing ones, and assign the component to it.
NoticeMake sure you assign the component to the node itself, not to a Node Reference.If the node you want assign this component to is a Node Reference, click Edit in the Parameters tab, and assign the component to the node directly.
- Open the component in IDE.
Moving Forward#
This section demonstrates how to set the forward movement of the mesh.
In this example, we use the "p" key pressing to move the mesh forward. The direction vector is visualized for clarity.
In the C# component file add the following (don't change the Component PropertyGuid, it is assigned by the system):
// MovementControls.cs
using System;
using System.Collections;
using Unigine;
#if UNIGINE_DOUBLE
using Vec3 = Unigine.dvec3;
using Vec4 = Unigine.dvec4;
using Mat4 = Unigine.dmat4;
#else
using Vec3 = Unigine.vec3;
using Vec4 = Unigine.vec4;
using Mat4 = Unigine.mat4;
#endif
[Component(PropertyGuid = "e3e22b2a2337e0813651bfec4f19ba5bb3e0abfe")]
public class MovementControls : Component
// define the movement speed
public float movement_speed = 5.0f;
private void Init()
// check if the key is pressed and update the state of the specified control
ControlsApp.SetStateKey(Controls.STATE_AUX_0, 'p');
private void Update()
// get the frame duration
float ifps = Game.IFps;
// enable visualizer
Visualizer.Enabled = true;
// get the current world transform matrix of the node
Mat4 transform = node.WorldTransform;
Vec3 direction = transform.GetColumn3(1);
// render the direction vector for visual clarity
Visualizer.RenderDirection(node.WorldPosition, new vec3(direction), new vec4(1.0f, 0.0f, 0.0f, 1.0f), 0.1f, false);
// check if the control key is pressed
if (ControlsApp.GetState(Controls.STATE_AUX_0) == 1) {
// calculate the delta of movement
Vec3 delta_movement = direction * movement_speed * ifps;
// set a new position to the node
node.WorldPosition = node.WorldPosition + delta_movement;
Another Way of Setting Mesh Position
The new position can be also set by setting the WorldTransform variable. The following examples contain the code from the Update() function of the AppWorldLogic class. The part of controls initialization is the same for this method, the difference is in the Update() function only.
node.WorldTransform = MathLib.Translate(delta_movement) * transform;
Or you can change the translation column of the world transformation matrix (see the Matrix Transformations article) to move the node:
// check if the control key is pressed.
// here, you can also use transform.setColumn3(3, transform.getColumn3(3) + delta_movement);
transform.SetColumn(3, transform.GetColumn(3) + new Vec4(delta_movement, 1.0f));
// set a new world transform matrix to the node
node.WorldTransform = transform;
Rotation#
This section contains implementation of the mesh rotation.
You can rotate the mesh in two ways, by changing the transformation matrix represented by the WorldTransform variable (recommended way) or via the SetWorldRotation() function. The following example uses the second one:
using System;
using Unigine;
#if UNIGINE_DOUBLE
#else
#endif
// define the rotation speed
public float rotation_speed = 30.0f;
private void Init()
ControlsApp.SetStateKey(Controls.STATE_AUX_1, 'o');
if (ControlsApp.GetState(Controls.STATE_AUX_1) == 1) {
// set the node rotation along the Z axis assuming node's scale equal to 1
node.SetWorldRotation(node.GetWorldRotation() * new quat(MathLib.RotateZ(rotation_speed * ifps)), true);
In the example above, the node is rotated to the left by pressing the "o" keyboard key.
- It is recommended to set the second argument of the SetWorldRotation() function to 1 for all non-scaled nodes to improve performance and accuracy.
- Scaling of nodes should be avoided whenever possible, as it requires addidional calculations and may lead to error accumulation.
To rotate the object by via the WorldTransform variable, you should replace the line containing the SetWorldRotation() function in the example above with the following one:
node.WorldTransform = node.WorldTransform * new Mat4(MathLib.RotateZ(rotation_speed * ifps));
This way is preferred, especially in case of complex transformations, as it allows to compose the transformation matrix and set it only once.
Combining Movements#
Combining different movement controls is not more difficult than adding only one movement control.
The following code is an example that adds a mesh to the world and assigns a component on it that allows controlling its movements. You can rotate the mesh by using the "o", "[" keyboard keys and move forward by using the "p" key.
using System;
using System.Linq;
using Unigine;
#if UNIGINE_DOUBLE
#else
#endif
private void Init()
// you can use both 'p', 'o', '[' or ASCII codes (112, 111, 113)
ControlsApp.SetStateKey(Controls.STATE_AUX_2, '[');
// get the current world transform matrix of the mesh
// initialize rotation and movement and update flag
Mat4 rotation = Mat4.IDENTITY;
Vec3 delta_movement = new Vec3(0.0f);
bool update_transform = false;
// check if the control key for movement is pressed
update_transform = true;
// check if the control key for left rotation is pressed
// set the node's left rotation along the Z axis
rotation.SetRotateZ(rotation_speed * ifps);
// check if the control key for right rotation is pressed
else if (ControlsApp.GetState(Controls.STATE_AUX_2) == 1)
// set the node's right rotation along the Z axis
rotation.SetRotateZ(-rotation_speed * ifps);
// update transformation if necessary
if (update_transform)
// combine transformations: movement + rotation
transform = transform * rotation;
transform.SetColumn3(3, transform.GetColumn3(3) + delta_movement);
// set the resulting transformation
