Startup Command-Line Options
Startup command-line options can be specified on the UNIGINE executable file launching. These options control what rendering API to use, what resolution to set for Unigine window, where resources for initializing the engine are stored, etc. The options are either set in UNIGINE SDK Browser or manually via the command line.
If no command-line options is specified, the options with default values will be used when launching the application.
The syntax of command-line options is as follows: the full name of the binary executable (32- or 64-bit, development or production version) is specified first and then the start-up options.
Shell commands
main_* -command argument
Shell commands
main_* -command "argument,argument"
Shell commands
main_* -console_command "command argument"
All paths are specified as absolute or relative to the binary executable or the data directory.
If the same command is specified multiple times, only the last command will be taken into account by the engine. For example, in the following case, only the argument3 will be used by the engine:
Shell commands
-command "argument1" -command "argument2" -command "argument3"
An exception is file system command-line options: they can accumulate all the specified values.
The CLI options specified on the application start-up always take precedence over the ones stored in the configuration file. Some of the CLI options can be changed through the console. Such options are automatically stored in the configuration file (this way, after the application is quit, they will be restored on the next start-up). All other CLI options don't change the configuration file.
Video Settings#
Name Description Arguments Default
-video_mode Video mode to set window resolution or size -1 is video_width ×video_height
0 is 640×360
1 is 960×540
2 is 1024×576
3 is 1280×720
4 is 1366×768
5 is 1600×900
6 is 1920×1080
7 is 2560×1440
8 is 3840×2160
9 is 640×400
10 is 960×600
11 is 1024×640
12 is 1280×800
13 is 1440×900
14 is 1680×1050
15 is 1920×1200
16 is 2560×1600
17 is 640×480
18 is 800×600
19 is 1024×768
20 is 1280×960
21 is 1280×1024
22 is 1600×1200
23 is 2048×1536
24 is 2560×2048
1
-video_width Screen width
Makes sense only if video_mode =-1
010000 0
-video_height Screen height
010000 0
-video_resizable Allows changing a window size on the fly, without having to restart the application 0 is a non-resizable mode
1 is a resizable mode
0
-video_fullscreen Fullscreen mode 0 is a windowed mode
1 is a fullscreen mode
2 is a fullwindow mode when an application window is rendered without decorations
0
Graphics Settings#
-video_app Graphics API to be used for rendering:
  • No renderer: do not render anything onto the screen (for example, for servers in case of playing over the network)
  • Automatically choose the best option from available ones
  • DirectX
  • OpenGL
The current value of -video_app can be obtained via the getVideoApp() method of Unigine API.
"null"
"auto"
"direct3d11"
"opengl"
"auto"
-video_adapter In case of several GPUs, allows selecting a GPU to be used.
Available for DirectX only.
The number of the GPU to be used. 0
-video_debug Enables or disables the debug context of OpenGL or DirectX.
Enabling the debug context may cause performance drop (~30-40%).
DirectX:
  • 0 to disable
  • 1 to write all DirectX errors (red) and warnings (yellow). If the error occurred, it means that there is a mistake in API.
  • 2 to write all DirectX errors (red) and warnings (yellow). If the error occurred, the engine will crash and the full callstack will be shown.
OpenGL:
  • 0 to disable
  • 1 to write all OpenGL errors (red) and warnings (yellow). If the error occurred, it means that there is a mistake in API.
  • 2 works in the same way as 1 mode.
0
-video_refresh Graphics refresh rate 0200 0
-video_quad_buffer Enables of disables quad buffered stereo. 0 to disable quad buffering
1 to enable quad buffering
0
-video_surround Allows rendering of the application across 3 monitors. 0 to disable rendering across 3 monitors
1 to enable rendering across 3 monitors
0
-video_surround_border Sets the size of monitor bezel compensation in pixels. It is used together with -video_surround 1. Size of the bezel compensation in pixels.
-video_vsync Vertical synchronization (synchronize FPS with monitor's refresh rate) 0 - don't use synchronization
1 - use synchronization
0
File System#
-data_path A path to the data directory with all resources. The path can be specified as an absolute path or relatively to the binary executable. The specified -data_path directory can be obtained via the getDataPath() function. The argument can be passed as follows:
  • ../RELATIVE_PATH/
  • ABSOLUTE_PATH
-plugin_path Path to a directory that contains plugins. All of the plugins in this directory will be loaded automatically on the start-up. The path can be specified relatively to the binary executable or as an absolute path. The list of the specified -plugin_path directories can be obtained via the getNumPluginPaths() and getPluginPath(int num) methods. The arguments can be passed as follows:
  • ../RELATIVE_PATH/
  • ABSOLUTE_PATH
plugins/
Unlike the other command-line options, the plugin_path option can accumulate all the specified values. It allows specifying multiple paths, each of which will be used by the engine.
For several directories or packages you should specify each item separately without commas, for example:
Source code
-plugin_path ../RELATIVE_PATH_1/ -plugin_path ../RELATIVE_PATH_2/ -plugin_path ABSOLUTE_PATH
Other Data#
-cache_path A path to store system and editor cache files (specified by system_cache and editor_cache respectively). The path can be specified as an absolute path or relatively to the -data_path.
For this parameter to take effect you should either detete existing system and editor cache files or move them to the new specified location.
  • ../RELATIVE_PATH/
  • ABSOLUTE_PATH
data/
-editor_cache A path to a cache file to be used by the UnigineEditor. The path can be specified as an absolute path or relatively to the -data_path, or to the -cache_path (if any). editor.cache
-system_cache A path to a cache file to be used by the Engine. The path can be specified as an absolute path or relatively to the -data_path, or to the -cache_path (if any). unigine.cache
-engine_config The configuration file used to read and store all global engine-related and project-related settings.
If the configuration file is stored in an .ung package, it won't be loaded and, therefore, the engine won't be initialized. However, when the file system is initialized, you can set the configuration file stored in the package via the config_load console command.
unigine.cfg
-engine_log The log file to be created and used. The path can be specified as an absolute path or relatively to the binary executable. For relative paths, if the -project_name is set, the log file with the specified name will be created in the corresponding directory in the User profile (only the name will be used, the remaining part of the relative path will be discarded). log.html
-editor_script Path to the editor script (specified relative to the data directory)
-gui_path A path to a GUI skin to be used for the engine interface. The path can be specified as an absolute path or relatively to the -data_path. core/gui/
-project_name Forces the engine to store all changing data (a log file, cache files and the configuration file) in the User profile rather than in a directory with binaries. For that, a directory will be created with a specified PROJECT_NAME. both a or a path to the project directory relative to the User profile (for example, unigine_projects/my_project). PROJECT_NAME, namely:
  • A name of the project directory. For example, -project_name my_project will create the following directory:
    • On Windows,
      C:/Users/<username>/my_project/
    • On Linux,
      /home/<username>/.my_project/
  • A path to the project directory relative to the User profile. For example, -project_name unigine_projects/my_project will create my_project directory in the following directory:
    • On Windows,
      C:/Users/<username>/unigine_projects/
    • On Linux,
      /home/<username>/.unigine_projects/
    The specified unigine_projects folder must exist in the User profile.
-system_script Path to the system script (specified relative to the data directory). core/unigine.usc
Engine-related Settings#
-console_command Console command to be used at the engine start-up. Several commands can be separated using the && sequence. command <arguments>
-extern_plugin Load a plugin library (the path is specified relative to the binary executable).
  • The library name should go without any prefixes and postfixes.
    (For example, libNetwork_x86d.so should be passed as "Network".)
  • Several plugins are comma separated (no whitespace).
  • If you want to clear the list of plugins (they are automatically loaded by the engine once specified on the start-up), simply pass "" as an argument to this command.
The arguments can be specified as follows:
  • PLUGIN_NAME
  • PLUGIN_NAME_1,PLUGIN_NAME_2,...,PLUGIN_NAME_N
-extern_define External definition to be used.
  • Several definitions are comma separated (no whitespace).
  • You can also use the following syntax: -extern_define "A=B,C=D".
    (For example, -extern_define  "TEST=42" .)
  • If you want to clear all definitions, simply pass "" as an argument to this command.
The current value of -extern_define can be obtained via the getExternDefines() method of Unigine API.
  • DEFINITION_NAME
  • DEFINITION_NAME=VALUE
  • DEFINITION_NAME_1,DEFINITION_NAME_2,
    DEFINITION_NAME_3=VALUE,...,DEFINITION_NAME_N
Sound Settings#
-sound_app Sound API to be used:
  • No sound
  • Automatically choose the best sound library option from available ones (OpenAL)
  • OpenAL sound library
  • XAudio2 sound library
The current value of -sound_app can be obtained via the getSoundApp() method of Unigine API.
null
auto
openal
xaudio2
auto
Last update: 14.01.2020
