Creating End UI
The end widget should be visible when the game is over. The user will be able to restart the game or exit the application via the corresponding buttons.
Step 1. Make the World Widget Controller#
The widget controller node will specify the handlers for different types of UI elements and show the UI at the end of the game.
  1. Create a new C# component and call it UiElement. This component handles the selection and button functions calls. Open the UiElement component in your IDE and copy the code below. Don't forget to save your code.
    UiElement.cs
    UiElement.cs
    using System;
    using System.Collections;
    using Unigine;
    #if UNIGINE_DOUBLE
    using Vec3 = Unigine.dvec3;
    #else
    	using Vec3 = Unigine.vec3;
    #endif
    public class UiElement : Component
    	[ShowInEditor][Parameter(Tooltip = "Type of UI element")]
    	private Element uiType = Element.None;
    	[ShowInEditor][ParameterMask(Tooltip = "Mask for detecting mouse intersection")]
    	private int uiMask = 1;
    	[ShowInEditor][Parameter(Tooltip = "Scale on hover")]
    	private float selectScale = 1;
    	[ShowInEditor][ParameterColor(Tooltip = "Emission color on hover")]
    	private vec4 selectEmission = vec4.ONE;
    	static public event Action<Element> onClick;
    	public enum Element { Restart, Exit, None }
    	public uint Id { get; private set; }
    	static public bool AnyIsSelect
    		get
    			if (selectedObjects == 0)
    				return false;
    			return true;
    	// ID of UI element
    	static private uint idCount = 0;
    	// count of selected objects
    	static private int selectedObjects = 0;
    	private WorldIntersection intersection = null;
    	private bool isSelect = false;
    	Unigine.Object uiObject = null;
    	private vec3 sourceScale = vec3.ONE;
    	private vec4 sourceEmission = vec4.ONE;
    	void Init()
    		// set ID
    		Id = idCount;
    		++idCount;
    		// get the UI element
    		uiObject = node as Unigine.Object;
    		// remember the source scale and emission color
    		sourceScale = node.Scale;
    		sourceEmission = uiObject.GetMaterialParameterFloat4("emission_color", 0);
    		intersection = new WorldIntersection();
    	protected override void OnDisable()
    		// deselect an object
    		if (isSelect)
    			--selectedObjects;
    			if (selectedObjects < 0)
    			isSelect = false;
    			OnLeave();
    	void Update()
    		// getting direction from the current mouse position
    		ivec2 mouse = Input.MousePosition;
    		vec3 dir = Game.Player.GetDirectionFromMainWindow(mouse.x, mouse.y);
    		// get points for intersection
    		Vec3 p0 = Game.Player.WorldPosition;
    		Vec3 p1 = p0 + dir * 25.0f;
    		// find the intersection
    		Unigine.Object obj = World.GetIntersection(p1, p0, uiMask, intersection);
    		if (obj != null)
    			// try to get the UI element component and select/deselect it
    			UiElement uiElement = ComponentSystem.GetComponent<UiElement>(obj);
    			if (uiElement != null && uiElement.Id == Id)
    				if (!isSelect)
    					OnEnter();
    					isSelect = true;
    					++selectedObjects;
    			else if (isSelect)
    				OnLeave();
    				isSelect = false;
    				--selectedObjects;
    		else
    			if (isSelect)
    				OnLeave();
    				isSelect = false;
    				--selectedObjects;
    		// invoke the mouse click event
    		if (isSelect && Input.IsMouseButtonDown(Input.MOUSE_BUTTON.LEFT))
    			OnClick();
    	private void OnEnter()
    		// set a visual effect on selection
    		node.Scale = sourceScale * selectScale;
    		uiObject.SetMaterialParameterFloat4("emission_color", selectEmission, 0);
    	private void OnLeave()
    		// remove a visual effect when the UI element is not selected anymore
    		node.Scale = sourceScale;
    		uiObject.SetMaterialParameterFloat4("emission_color", sourceEmission, 0);
    	private void OnClick()
    		onClick?.Invoke(uiType);
  2. Next, add a win condition check, end widget text, and a delegate call to the LevelManager class. To do so, open the LevelManager component in an IDE and add the following code. Save your code in an IDE to ensure it's automatic compilation on switching back to UnigineEditor.
    LevelManager.cs
    using System;
    using Unigine;
    public class LevelManager : Component
    	public event Action endGameEvent;
    	ObjectText endText;
    //=========================== NEW - END ================================
    	// level timer
    	public float timer = 100.0f;
    	bool isCounting = true;
    	int physicalObjectsNum;
    	WidgetLabel widget_timer, widget_goal;
    	void Init()
    		InitGUI();
    		// find the object text node of the widget
    		endText = Game.Player.FindNode("header_text", 1) as ObjectText;
    		// count physical objects in the level
    		physicalObjectsNum = node.NumChildren;
    	void InitGUI()
    		// getting a GUI pointer
    		Gui gui = Gui.GetCurrent();
    		// creating a label widget and setting up its parameters
    		widget_timer = new WidgetLabel(gui, "Time Left:");
    		widget_timer.SetPosition(10, 10);
    		widget_timer.FontColor = vec4.RED;
    		widget_goal = new WidgetLabel(gui, "Objects Left: ");
    		widget_goal.SetPosition(10, 30);
    		widget_goal.FontColor = vec4.BLUE;
    		// add widgets to the GUI
    		gui.AddChild(widget_timer, Gui.ALIGN_OVERLAP);
    		gui.AddChild(widget_goal, Gui.ALIGN_OVERLAP);
    	void Update()
    		// decrease the timer
    		if (isCounting)
    			timer -= Game.IFps;
    			if (timer <= 0)
    				//end game
    //========================== NEW - BEGIN =============================
    				endText.Text = "Game Over";
    				endGameEvent?.Invoke();
    				isCounting = false;
    		//win
    		if (physicalObjectsNum <= 0)
    			endText.Text = "Success!";
    			isCounting = false;
    		// show the current time and objects left to clear
    		if (isCounting)
    			widget_timer.Text = "Time Left: " + timer.ToString("0.0") + " s";
    			widget_goal.Text = "Objects Left: " + physicalObjectsNum.ToString();
    		//hide the widgets on end game
    		else
    			widget_timer.Enabled = false;
    			widget_goal.Enabled = false;
    	void Shutdown()
    		widget_timer.DeleteLater();
    		widget_goal.DeleteLater();
    	public void DecPhysicalObjectsNum()
    		physicalObjectsNum--;
  3. Create a new C# component and call it EndWidget. Open the component in your IDE and copy the code below. Save your code in an IDE to ensure it's automatic compilation on switching back to UnigineEditor.
    EndWidget.cs
    using System;
    using Unigine;
    public class EndWidget : Component
    	// object with the end game message
    	public Node endGameWidget;
    	LevelManager levelManager;
    	void Init()
    		// set the end game event handler
    		levelManager = ComponentSystem.FindComponentInWorld<LevelManager>();
    		if (levelManager != null)
    			levelManager.endGameEvent += EndGameEventHandler;
    		// set the mouse click handler for UI elements (Restart/Exit)
    		UiElement.onClick += OnClickHandler;
    		// hide the end UI
    		endGameWidget.Enabled = false;
    	void EndGameEventHandler()
    		// set gui and input
    		Input.MouseHandle = Input.MOUSE_HANDLE.USER;
    		// show the end UI
    		endGameWidget.Enabled = true;
    	void OnClickHandler(UiElement.Element uiType)
    		// restart the level by reloading the world
    		if (uiType == UiElement.Element.Restart)
    			Unigine.Console.Run("world_reload");
    		// exit the game
    		if (uiType == UiElement.Element.Exit)
    			Engine.Quit();
    	void Shutdown()
    		// remove handlers
    			levelManager.endGameEvent -= EndGameEventHandler;
    		UiElement.onClick -= OnClickHandler;
  4. Switch to the UnigineEditor, create a new Dummy Node, call it "widgets_controller" and assign the EndWidget component to it.
Step 2. Set Up the World Widget#
The end widget provides button functionality and additional information about the current game outcome. To properly display the end widget, position it in front of the camera.
  1. Drag the programming_quick_start\ui\ui_plane.node from the Asset Browser to the world.
  2. Parent it to the PlayerDummy camera. Set the position of the ui_plane node to the following values.
  3. Click the Edit for the ui_plane NodeReference and expand the hierarchy.
  4. Assign a UiElement component to the child restart_button node.
  5. Set the Ui Type to Restart, check the 6th bit option for the Ui Mask (matching the button's Intersection Mask) to correctly process selection intersections and set the Select Scale to 1.05 in order to make buttons bigger on cursor hover. Also, set the Select Emission to #505050 to make the button change its color.
  6. Set up a new UiElement component the same way for the exit_button, but set the Ui Type to Exit.
  7. Confirm the node reference editing by clicking Apply in the Parameters window of the ui_plane node.
  8. Assign the ui_plane node to the End Game Widget field under the EndWidget component of the widgets_controller node.
  9. Save changes to the world, go to File->Save World or press Ctrl+S hotkey. Build and run the game to see the UI in action.
Last update: 2023-12-20
