Projections with AppProjection Plugin
AppProjection allows you to create multi-projector setups. Edge blending, non-linear image mapping and color correction for each projection are supported. Therefore, AppProjection can project images onto large curved screen displays covering 360 degrees, if necessary. Moreover, each projection can be fully customized to use required view frustums.
Projection setup
Projection setup
AppProjection
Customizable projection with AppProjection
Launching AppProjection
To launch the application and render projections:
  1. Specify an engine plugin library (lib/AppProjection_*) together with the rest of required start-up arguments (such as rendering API, window size, etc.). For example:
    Shell commands
    bin\main_x86d.exe -extern_plugin AppProjection
    You can use 32-bit, 64-bit, debug or release versions of the library. (The engine automatically loads the appropriate version of the library depending on the specified main application.)
    It is not possible to use AppProjection with:
  2. To change the number of displays in a row, specify -width CLI option. For example:
    Shell commands
    bin\main_x86d.exe -extern_plugin AppProjection -width 2
    By default, up to 8 projections are supported to be output from one rendering node.
AppProjection with two projections
Setting Up Projections
To set up projections, open the system menu by pressing Esc, go to Plugins tab and click Projection button.
The Projection Configurator window will open. Here, it is possible to:
For the last three options, you should first choose a Projection to be adjusted at the top-right corner.
Warping
The Warp tab allows you to set up geometry correction for your projections. Areas where geometry correction is required include:
  • Advanced off-axis correction where projector placement is awkward and needs an advanced mapping over the keystone function in a projector
  • Non-planar screens such a curved screens and hemispherical domes
  • Projecting one image from one projector onto more than one surface
  • Unusual projection applications onto custom designed screens
The following options are available:
Projection Allows you to choose a projection in the drop-down list to set up its parameters: warping, edge blending and color correction.
Resolution Warping is performed by defining a grid. A 2 x 2 grid is used by default. You can set the number of control points for the grid along horizontal and vertical axes.
Points Visual editor enables you to set up warping for the selected projection using control points and yellow handles. These handles are displayed for each selected control point depending on its type.
The maximum grid size is 32 x 32.
  • Drag control points and their yellow handles to warp the projection and adjust it for the required configuration.
    You can see an example of warped grid and a corresponding projection image below.
    Warped grid
    Warped grid
    Warped image
    Warped image
  • You can fine-tune projection warping by adjusting the parameters of each control point by selecting it and changing parameters via the following panel next to grid resolution settings
    The following parameters are available
    • Point - horizontal and vertical indices of the selected control point.
    • Position - coordinates of the selected control point along X and Y axes. Coordinates for points and handles
      Coordinates for control points
    • Type - warping type for the selected control point:
      • - automatic linear interpolation (no control handles available)
      • - symmetric control handles for smooth curves
      • - asymmetric control handles (you can control each handle independently)
      • - automatic smooth curve (no control handles available)
Canvas Here you can configure the canvas for the selected projection: set rotation angle and enable vertical and horizontal flipping.
Render The Debug option allows you to temporarily set individual colors for different projections. This helps to visualize overlapping regions for different projections and facilitates the setup process.
Color Correction
The Color tab allows you to correct color intensity, as well as to adjust color balance for the selected projection.
Scale Per-channel color multiplier. It allows to control the intensity of:
  • Red
  • Green
  • Blue
  • RGB at once
Red channel scale
Scale for the red channel = 2
Bias allows you to adjust the color balance per channel (as well as for all channels at once):
  • Positive values (up to 1) are added to the color values on the screen.
  • Negative values (starting from -1) are subtracted from color values on the screen.
Red channel bias
Bias for the red channel = -0.1
Edge Blenging and Masking
The Blend & Mask tab allows you to configure blending along the edges and according to masks, you can also use masks to cut out certain areas for the selected projection.
Mask This group allows you to set up masks to be used for blending regions or to cut out certain areas (e.g. top and bottom areas for a curved screen projection).
The list of masks for the current projection is displayed on the left. You can add new masks and remove existing ones using the corresponding buttons.
Visual editor enables you to create and modify masks.
  • To add new points to the mask selected in the list, you should click Creation Mode button. Then you can add new points by clicking within the grid area, new points will be placed at the mouse cursor. To insert a new point into an existing mask, select the point next to which a new point is to be added, and click to insert a new one. You can drag an existing point to move it. To remove a point, simply right-click it.
  • You can also adjust your masks precisely by specifying the coordinates of each point. Select a point on the grid (its color will turn to white) and enter the coordinates in the corresponding Position fields below.
    You can change the type of the selected control point using the following icons:
As you select a mask in the list, its parameters are displayed on the panel next to it:
  • Name - mask name.
  • Smooth - smoothing of mask edges. Determines the number of additional points to be inserted between the control points.
  • Border Size controls the width of the blended area along the edges of the mask polygon (analogous to Size parameter for the border):
    • 0 - there is no blending.
    • 1 - a half of the screen is blended.
  • Outer Alpha - opacity of the mask border area along the edges:
    • 0 - the mask is fully transparent.
    • 1 - the mask is fully opaque.
  • Inner Alpha - opacity of the mask polygon:
  • Power controls how fast the screen is blended across the area specified by Size (analogous to Power parameter for the border).
    • The higher the value, the larger the black area is.
Border Controls soft edge blending for each side of the projection (left, right, top or bottom one). Set a non-zero Power value to start setting it up.
  • Gamma - gamma correction value.
  • Offset - viewport clipping offset. The clipped part is rendered in black.
    • 0 - the whole viewport is shown.
    • 1 - a half of the viewport is cut out.
    Low Offset
    Offset = 0.1
    High Offset
    Offset = 1
  • Size controls the size of the blended area:
  • Power controls how fast the screen is blended across the area specified by Size.
    Low Power
    Power = 1
    High Power
    Power = 5
Multiple Projections' Viewing Settings
If more than two projections are created with AppProjection, the following viewing settings can be tweaked in the System menu -> Plugins.
FOV The field of view for all projections. (Camera tab -> Field of view option is not applicable in this case).
Small Field of view
Fov = 60
Large Field of view
Fov = 80
Angle Allows to adjust the viewing angle between projections. That is, when surfaces to project the images onto are turned at some angle to each other, this angle can be entered as Angle value and the projection will be automatically recalculated to show the right image.
For example, if two surfaces are turned to each other at 40 degrees:
Angle
Angle = 40 degrees
Bezel  X Compensates for horizontal bezel of monitors. Positive values decrease the viewport space; negative ones increase it (for overlapping).
Saving and Loading Presets
After projection configuration is set up, it can be saved to an preset file (*.proj) to be loaded at any time (e.g. to set up another projection):
  • Save button to save a preset file
  • Load button to load a preset file
A *.proj file that you save will only contain settings for the currently selected projection.
Customizing AppProjection
AppProjection can be customized to support custom viewing frustums (symmetric or asymmetric ones) for each projection.
AppProjection Viewports
AppProjection has one primary viewport, while all others are rendered as auxiliary ones. By default, the primary display is the Unigine engine viewport used for one-monitor configuration. It uses matrices of the Player used by the engine to view the scene. Other displays are arbitrary cameras with any perspective and facing whatever direction needed. Each display has its own model-view and projection matrices. Both the primary projection and auxiliary ones can be enabled or disabled, if necessary.
  • The primary viewport can be set to any projection (for supported configurations it is already set).
  • Each viewport has its own model-view and projection matrices.
  • By default, only a primary one has a graphical user interface (render system GUI, editor widgets, wireframe, or the profiler). However, separate GUIs can be drawn on all projections.
  • All viewports have their own viewport and reflection mask to selectively render nodes and reflections from them.
Default Configurations
For default configurations, the primary viewport is set to the following projection:
  • For 2 projections, the 1st viewport.
  • For 3 projections, the 2nd viewport.
  • For 4 projections, the 2nd viewport.
  • For 5 projections, the 3rd viewport.
How to Customize Projections
Rendering of AppProjection viewports is controlled by wall.h script (found in <UnigineSDK>/data/core/scripts/system/ folder). There are two possible setups depending on how the primary projection is rendered. It can be drawn by:
  • The default engine renderer (the same as when a usual one-monitor application is rendered).
  • The AppProjection renderer itself (which is safer if you are going to use asymmetric frustum for the center projection and modify its model-view matrix).
Only one of two renderers should be enabled at the same time.
The following example demonstrates how to tweak cameras configuration and choose the renderer for the main projection.
1. Using default engine renderer
The first variant is to render the main (primary) projection by the default engine renderer.
  1. In case the created configuration is not already supported, set the primary projection via engine.projection.setPrimary():
    Source code (UnigineScript)
    // Set the first projection as a primary one
    	engine.projection.setPrimary(0,1);
  2. Enable all non-primary projections via engine.projection.setEnabled(). The main one should be left disabled, as it is drawn by the default engine renderer.
    // Enable the 2nd projection in a row
    	// The second argument of the function sets 'enabled' flag
    	engine.projection.setEnabled(1,1);
  3. Set projection and model-view matrices for an auxiliary projection via engine.projection.setProjection() and engine.projection.setModelview().
    // Settings for the 2nd projection
    	engine.projection.setProjection(1,projection_1);
    	engine.projection.setModelview(1,modelview_1);
2. Using AppProjection renderer
Another variant is to render the main projection by the AppProjection renderer. This variant can be used, for example, if you want to set up symmetric frustums for all projections.
  1. Set the projection to be used as a primary one and enable its rendering by AppProjection.
  2. Disable rendering into the default Unigine viewport via engine.render.setEnabled():
    engine.render.setEnabled(0);
  3. Enable all AppProjection projections including the primary one. As a result, all viewports will be rendered by AppProjection renderer itself:
    // Enable all projections
    	engine.projection.setEnabled(0,1);
  4. Set model-view and projection matrices for all projections.
    // Settings for the 1st projection
    	engine.projection.setProjection(0,projection_0);
    	engine.projection.setModelview(0,modelview_0);
Last update: 2018-04-26
