Clouds
This section contains settings for clouds.
Clouds Settings
Sampling Quality This parameter determines the number of samples used and affects cloud density. The following values are available:
  • Low - 1 noise sample, low quality (higher density).
  • Medium - 3 samples, medium quality (by default).
  • High - 5 samples, high quality.
  • Ultra - 6 samples, ultra quality (lower density, the clouds are softer).
Visual difference between low and ultra quality is not significant. Therefore, it is recommended to use low settings, when possible, to gain performance.
Lighting Quality This parameter determines the number of samples used to calculate lighting for clouds. The following values are available:
  • Low - 1 sample, low quality.
  • Ultra - 6 samples, ultra quality.
This parameter has a significant impact on performance. Therefore, it is recommended to use low settings, when possible.
Samples Count This parameter determines the number of samples used for clouds rendering. The following values are available:
Lighting Trace Length This parameter determines the maximum length of a sun ray traced inside a cloud, in units.
Lighting Cone Radius Lighting cone sampling radius for clouds lighting.
Low values may result in unnatural behavior as the position of the sun changes.
Dynamic Coverage Area This parameter determines visibility distance for coverage of FieldWeather objects, in units.
In UnigineEditor this area is marked with a bounding box. When the camera is outside this box, the FieldWeather coverage is not visible.
Increasing dynamic coverage area leads to reduction of quality of FieldWeather coverage texture and loss of details. This effect can be mitigated by increasing dynamic coverage resolution.
Dynamic Coverage Resolution This parameter determines the quality of dynamic coverage texture for FieldWeather objects. The following values are available:
  • 128 x 128.
  • 256 x 256 (by default).
  • 512 x 512.
  • 1024 x 1024.
  • 2048 x 2048.
Higher values make it possible to preserve texture details at high distances.
Interleaved Rendering Interleaved rendering mode for clouds. The following values are available:
  • disabled (by default).
  • 2 x 2.
  • 4 x 4.
In cases when clouds are viewed from the ground, or from above (at significant distance) and viewer's velocities are less than 200 units per second. This parameter can be used to provide a significant gain in performance.
Downsampling Rendering This parameter determines clouds resolution based on current screen resolution. The following values are available:
  • Full - full resolution.
  • Half - half resolution (by default).
  • Quad - quarter resolution.
Soft Intersection This parameter determines soft intersection distance for clouds in meters.
Render After Transparent This parameter enables rendering of clouds after all transparent objects (except water).
Last update: 2018-04-26
