Attaching Object to HMD
Sometimes, it might be necessary to attach some object to the HMD to follow it. It can be a menu (like the head_menu node in the sample), glasses with colored lenses, or a smoking cigar. To attach a node to the HMD position, assign the AttachToHead property to this node and specify the required settings: distance, forward direction axis (to properly orient the node facing the viewer), and flags indicating whether the node position is fixed and updated when the component is enabled.
