Customizing Menu
The VR template has two menu types: the main one is attached to the HMD position, and the second — to the hand. In the VR sample, the MenuAttachedToHead node (ObjectGui) is used for the main menu, and the vive_menu node (ObjectGui) is used for the additional menu. Each node is added as a child to the corresponding controller node (for example, vive_left_controller).
All menu nodes have the same VRMenuSample.cs component assigned. It is inherited from the base VRBaseUI component that implements a user interface. In general, the user interface is implemented as follows:
- Inherit a new component from the base VRBaseUI.
- Implement the user interface with the required widgets in the overridden InitGui() method.
- Implement callbacks for processing widgets events (pressing a button, selecting elements in the drop-down menu, etc.).
- Add the callbacks to the corresponding widgets in the InitGui() method.
- Assign the component to the ObjectGui node that will display the user interface.
Let's create a new menu for the left controller and add the quit button:
Inherit a new component from the base VRBaseUI, call it VRHandMenu and copy the following code to it:
using System; using System.Collections; using System.Collections.Generic; using Unigine; [Component(PropertyGuid = "AUTOGEN_GUID")] // <-- an identifier is generated automatically for the component public class VRHandMenu : VRBaseUI { // declare required widgets private WidgetSprite background; private WidgetVBox VBox; private WidgetButton quitButton; private WidgetWindow window; private WidgetButton okButton; private WidgetButton cancelButton; private WidgetHBox HBox; // overriden method that is called on interface initialization, // it adds the required widgets and sets callbacks protected override void InitGui() { if (gui == null) return; background= new WidgetSprite(gui, "core/textures/common/black.texture"); background.Color = new vec4(1.0f, 1.0f, 1.0f, 0.5f); gui.AddChild(background, Gui.ALIGN_BACKGROUND | Gui.ALIGN_EXPAND); // add a vertical column container WidgetVBox to GUI VBox = new WidgetVBox(); VBox.Width = gui.Width; VBox.Height = 100; gui.AddChild(VBox, Gui.ALIGN_OVERLAP|Gui.ALIGN_CENTER); // add the quit button to the container quitButton = new WidgetButton(gui, "QUIT APPLICATION"); quitButton.FontSize = 20; VBox.AddChild(quitButton); quitButton.AddCallback(Gui.CALLBACK_INDEX.CLICKED, ButtonQuitClicked); VBox.Arrange(); // create a quit confirmation window window = new WidgetWindow(gui, "Quit Application"); window.FontSize = 20; // add a horizontal row container WidgetHBox to the confirmation window HBox = new WidgetHBox(); HBox.Width = window.Width; HBox.Height = 100; window.AddChild(HBox); // add the "OK" button and assign the "OkClicked" callback that will close the application okButton = new WidgetButton(gui, "OK"); okButton.FontSize = 20; HBox.AddChild(okButton); okButton.AddCallback(Gui.CALLBACK_INDEX.CLICKED, OkClicked); // add the "Cancel" button and assign the "OkClicked" callback that will close the confirmation window cancelButton = new WidgetButton(gui, "Cancel"); cancelButton.FontSize = 20; HBox.AddChild(cancelButton); cancelButton.AddCallback(Gui.CALLBACK_INDEX.CLICKED, CancelClicked); } // callback to be fired on clicking "quitButton" private void ButtonQuitClicked() { gui.AddChild(window, Gui.ALIGN_OVERLAP | Gui.ALIGN_CENTER); } // callback to be fired on clicking "cancelButton" private void CancelClicked() { gui.RemoveChild(window); } // callback to be fired on clicking "okButton" private void OkClicked() { // quit the application Engine.Quit(); } }
- component to the vive_menu node
Assign the VRHandMenu.cs component to the vive_menu node (the child of the vive_left_controller node).
- Save changes (Ctrl+S) and press the Play button to run the application.
After launching the application, press the Menu button on the left controller — the result will look similar to this:
