Unigine Basics
1. Introduction
2. Managing Virtual Worlds
3. Preparing 3D Models
4. Materials
5. Cameras and Lighting
9. Physics
10. Optimization Basics
Adding a New Interactable Object
Let's add a new type of interactable object that we can grab, hold, and throw (it will be inherited from the VRBaseInteractable component) with an additional feature: some visual effect (for example, smoke) will appear when we grab the object and, it will disappear when we release the object. In addition, it will display certain text in the console if the corresponding option is enabled.
  1. Create a new VRObjectVFX component and add the following code to it:
    Source code (C#)
    using System;
    using System.Collections;
    using Unigine;
    [Component(PropertyGuid = "AUTOGEN_GUID")] // <-- an identifier is generated automatically for the component
    public class VRObjectVFX : VRBaseInteractable
      // an asset with an effect that occurs when the object is grabbed
      public AssetLinkNode vfx_node = null;
      private Node vfx = null;
      private Unigine.Object obj = null;
      // this method is called for the interactable object each frame
      private void Update()
     	// update transformation of the effect if the object is grabbed
     	if(CurrentState == VRBaseInteractable.INTERACTABLE_STATE.GRABBED)
       	vfx.WorldTransform = node.WorldTransform;
      // this overridden method is called after component initialization
      // (you can implement checks here)
      protected override void OnReady()
    	// check if the asset with the visual effect is specified
    	if (vfx_node == null)
       		Log.Error($"{nameof(VRObjectVFX)} error: 'vfx_node' is not assigned.\n");
       		Enabled = false;
       		return;
    	else
    			vfx = vfx_node.Load();
    			vfx.Enabled = false;
      // this overridden method is called when grabbing the interactable object
      public override void OnGrabBegin(VRBaseInteraction interaction, VRBaseController controller)
     	// show the effect
     	vfx.Enabled = true;
     	// set the current object state to GRABBED
     	CurrentState = VRBaseInteractable.INTERACTABLE_STATE.GRABBED;
      // this overridden method is called when releasing the interactable object
      public override void OnGrabEnd(VRBaseInteraction interaction, VRBaseController controller)
     	// hide the effect
     	// set the current object state to NOT_INTERACT
     	CurrentState = VRBaseInteractable.INTERACTABLE_STATE.NOT_INTERACT;
  2. Assign the VRObjectVFX.cs component to the cylinder node (the child of the kinematic_movable dummy node).
  3. Drag the vr/particles/smoke.node asset to the Vfx Node field. This node stores the particle system representing the smoke effect. It is available in the vr/particles folder of the UNIGINE Starter Course Projects add-on.
  4. Save changes (Ctrl+S) and press the Play button to run the application.
Now, if you grab and hold the cylinder, it will emit smoke:
Last update: 2024-04-08
