cor Posted August 29, 2011 Share Posted August 29, 2011 Hi all, I'm searching for a suitable terrain editor that can be used to generate the terrain input for Unigine. Can anybody advise? Thanks. Link to comment
ulf.schroeter Posted August 29, 2011 Share Posted August 29, 2011 This thread might be useful. WorldMachine is a tremendous tool for procedural terrain generation. If you have to use real-world terrain data GlobalMapper is a very good tool for raw data convertion. Third option is usage of UNIGINE build-in terrain editor. Link to comment
cor Posted August 29, 2011 Author Share Posted August 29, 2011 Third option is usage of UNIGINE build-in terrain editor. When using the build-in editor, do I still need to generate the height maps or other stuff externally? Is the build in editor power full ? Link to comment
ulf.schroeter Posted August 29, 2011 Share Posted August 29, 2011 Have a look into documentation, there is a tutorial on terrain creation. Is the build in editor pwer full? Decide on your own, here is an example. Most probably for complex and large terrains procedural tools like WorldWind are more powerful, but have a non-trival learning curve. Link to comment
cor Posted August 29, 2011 Author Share Posted August 29, 2011 Have a look into documentation, there is a tutorial on terrain creation. There is a tutorial about adding terrain. It assumes that you already have the height map and diffuse texture etc. This is the reason I was asking for terrain editing applications. I did read the documentation about terain editing, but I do not know from this if it will be powerfull enough. I wish there was a tutorial on terrain creation. Link to comment
ulf.schroeter Posted August 29, 2011 Share Posted August 29, 2011 I do not know from this if it will be powerfull enough. I wish there was a tutorial on terrain creation. Just try it on your own. You can use Unigine object sample ( start demos/samples_objects_...bat ) as a starting point for terrain editor usage. Activate editor mode, select terrain node and start terrain editing. Link to comment
ulf.schroeter Posted August 30, 2011 Share Posted August 30, 2011 I wish there was a tutorial on terrain creation. First-steps WorldMachine tutorial on procedural terrain creation. WorldMachine output height and texture maps can then be used as UNIGINE input textures as described in UNGINE terrain tutorial. Link to comment
