sebastian.vesenmayer Posted May 27, 2021 Share Posted May 27, 2021 Hello, when creating the standard project from the editor (material ball with plane) and start it with a 4K resolution it takes between 12 and 17 milliseconds to render on a RTX6000/RTX 2080, which is most of the render budget for 60 fps. Are there 4K optimized settings for Unigine 2.14. Thanks, Sebastian Link to comment
silent Posted May 27, 2021 Share Posted May 27, 2021 Hi Sebastian, I'm afraid it's physically not possible to create a generic "4K preset" that will work for most of the cases. Each project is different, so I think it's better to spend some time with rendering profiler and adjust all the rendering settings so you will get a good balance for your scene/hardware/resolution setup. General advice for 4K currently is to use half / quarter post processing effects if possible and slightly lower overall settings. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
sebastian.vesenmayer Posted May 27, 2021 Author Share Posted May 27, 2021 (edited) So for your Superposition example you have a 4K optimized setting. Should I start from there? Edited May 27, 2021 by sebastian.vesenmayer Link to comment
silent Posted May 28, 2021 Share Posted May 28, 2021 I don't think that it would be applicable for you exact application. You can check the basic settings and adjust them further - that would be a good start. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
