jaaaaa Posted August 3, 2020 Share Posted August 3, 2020 (edited) Hi All, According to to the pricing site, glTF is a supported format in Unigine. However I stumbled upon some issues while toying around with it. - When importing PBR models, the shading texture is not set (Albedo, Normal and Emission work most of the time). The texture is imported correctly and can be set manually without a problem, however I think this should happen automatically as it does for the other textures. - Animations are not imported (all imported meshes are static) I used the official samples provided by Khronos: https://github.com/KhronosGroup/glTF-Sample-Models What did I do? - create subdir in data folder - click "Import" in Asset Browser - select *.gltf and *.bin file of sample asset and click "open" - drag and drop imported *.gltf into scene Here are my import settings (I played around a bit with them but could not solve the problems): Recreate the issues: - create new Unigine Project - import samples from glTF-Sample-Models repo (I used glTF-Sample-Models/2.0/BrainStem for animations and glTF-Sample-Models/2.0/BoomBox for the shading texture) Am I doing something wrong or is this a problem with the Unigine glTF importer? I can't find Documentation on glTF, maybe something like the FBX Import Guide would be useful? Thanks in advance! Greetings Edited August 3, 2020 by ipg_jallmenroeder Link to comment
morbid Posted August 4, 2020 Share Posted August 4, 2020 Hello, Thanks for the detailed report. At the moment shading texture is ignored on purpose. UNIGINE requires channels remapping for these textures and automatic assigning of the default ones will cause visual artifacts. Channels remapping feature was already implemented and waits to be tested. This improvement will be available later. Meanwhile, the only workaround is manual management of the shading texture. Sorry for the inconvenience. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
jaaaaa Posted August 4, 2020 Author Share Posted August 4, 2020 Thanks for the response. Anything on animations? I could not get them to work (easily) with glTF. And could you specify approximately when "available later" is? The glTF support seems to be in a somewhat early stage. Is there a roadmap for full support? Thanks and Greetings Link to comment
morbid Posted August 4, 2020 Share Posted August 4, 2020 By later I meant 2.13+, there's no concrete ETA because glTF importer development is under low priority. However, this can be changed. Is glTF your major format? How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
jaaaaa Posted August 4, 2020 Author Share Posted August 4, 2020 We are currently restructuring our workflow and evaluate glTF as an alternative because of its clear specification and open format. Channel remapping for shading textures does not seem like a big issue, I am sure there are ways to make this work. However animations would be necessary and I found samples where not only the shading texture but also albedo was not imported (glTF-Sample-Models/2.0/MetalRoughSpheres). Are there more hiccups to be expected when using glTF? Greetings Link to comment
morbid Posted August 4, 2020 Share Posted August 4, 2020 37 minutes ago, ipg_jallmenroeder said: However animations would be necessary and I found samples where not only the shading texture but also albedo was not imported (glTF-Sample-Models/2.0/MetalRoughSpheres). Hmm, that worked for me. The model includes albedo and shading map textures, albedo (image_0.png) was added automatically. 38 minutes ago, ipg_jallmenroeder said: Are there more hiccups to be expected when using glTF? Animation support and shading texture conversion are the major problems by now. We also had rare crashes with specific glTF files. On the other hand we have long time supported FBX and OBJ, these formats will provide a smoother experience. Thanks. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
jaaaaa Posted August 4, 2020 Author Share Posted August 4, 2020 (edited) Okay thanks for the help. Maybe you could update Documentation on glTF. From the Get Unigine site it looks like full glTF support, but it never appears in Documentation (I'd expect it in Import System for example). 36 minutes ago, morbid said: Hmm, that worked for me. The model includes albedo and shading map textures, albedo (image_0.png) was added automatically. Hm strange, I also had problems with the sponza scene that just vanished later. Maybe I messed up my import settings in the process. But its not an important issue so don't mind it. Greetings Edited August 4, 2020 by ipg_jallmenroeder Link to comment
