carlos.lozano Posted October 26, 2017 Share Posted October 26, 2017 We are creating an interior scene, the problem is that global lighting acts generating an unwanted effect. Is there any way to turn off global lighting, without the need to remove the sun? In the screenshots can be seen the change of lighting at different times of the day. Link to comment
silent Posted October 26, 2017 Share Posted October 26, 2017 Hi Carlos, To get rid of ambient color from WorldLight inside interior scenes you need to bake an Environment Probe. Please, refer to this article in order to get an idea how it works: https://developer.unigine.com/en/docs/2.6/objects/lights/envprobe/ If you have rectangular-shaped rooms it's better to use Box Projection (it can give you better visuals). You also can check our sample with Environment Probe setup in Samples -> Demos -> Samples 2.x -> lighting. P.S. don't forget to bake the EnvironmentProbe first with black lightning color to remove the ambient light :) Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
carlos.lozano Posted October 27, 2017 Author Share Posted October 27, 2017 Works perfectly, it's just what we needed. Thanks Silent. Link to comment
