Editor API
UnigineEditor public API
Editor Namespace Reference
Namespaces
 Internal
Classes
class  Action
 This basic class is used to represent any possible user action. More...
class  AssetManager
 This class is used to manage assets in the Editor. You can check if an asset with the specified GUID exists, get its file path, or subscribe for signals to perform certain actions when an asset is added, moved, updated, or deleted. More...
class  EnableNodeAction
 This class is used to represent any user's action changing node's enabled state. More...
class  IndexList
 This class represents a list of indices of selected subitems of a selected node. When an object is selected, some of its surfaces or collision shapes can also be selected, the index list shall contain indices for all of them grouped by type. More...
class  Plugin
 This class is used for plugin interface implementation when creating Editor plugins. It is a base class for all Editor plugins. More...
struct  PluginDependency
 Defines dependency on a plugin. More...
class  PluginInfo
 This class it is responsible for plugin loading/unloading and contains all necessary plugin metadata (name, version, dependencies, etc.). It can also be used to check the current plugin state and get information on errors (if any). More...
class  PluginManager
 The Editor::PluginManager is the main controller class of the Plugin System, it is responsible for:
  • Locating dynamic libraries in folders specified by the user.
  • Plugins initialization their lifecycle management and destruction via the instances of PluginInfo class.
  • Building plugins loading queue, as the order in which the plugins are loaded is important. If a plugin has a required dependency it expects for certain symbols to be loaded.
  • Providing the user with information on plugins. Currently used to build target UI in the Editor.
More...
class  RemoveNodesAction
 This class is used to represent any user's action removing nodes. More...
class  RenameNodeAction
 This class is used to represent any user's action changing node's name. More...
class  ReparentNodesAction
 This class is used to represent any user's action changing nodes parents. More...
class  Selection
class  SelectionAction
 This class is used to represent any user's selection action. More...
class  Selector
class  SelectorGUIDs
 Selector for GUIDs-based items (materials, properties, runtimes). An item of this type is associated with a file referred to via a GUID. More...
class  SelectorNodes
 This class is used to manage selected nodes along with their subobjects (such as surfaces, shapes, joints, billboards, etc.). More...
class  SetNodeTransformAction
 This class is used to represent any user's action setting node transforms. More...
class  Undo
 Undo manager class. This class is used to manage undo/redo operations for user actions in the Editor. More...
class  WindowManager
 Window manager class. This class is used to manage tool windows in the Editor. More...
Enumerations
enum  SelectorType {
  SELECTOR_NODES = 0, SELECTOR_MATERIALS, SELECTOR_PROPERTIES, SELECTOR_RUNTIMES,
  SELECTOR_USER = 0x0100
 Selector type, defines the type of selected entities. The first 256 types are reserved by UNIGINE, user selector types start from SELECTOR_USER + i (256 and higher). More...
Functions
uint qHash (const PluginDependency &value)
Enumeration Type Documentation
◆ SelectorType
Enumerator
SELECTOR_NODES
Nodes selector.
SELECTOR_MATERIALS
Materials selector.
SELECTOR_PROPERTIES
Properties selector.
SELECTOR_RUNTIMES
Runtimes selector.
SELECTOR_USER
Beginning of the range of user-defined types. Types are referred to as SELECTOR_USER+0, SELECTOR_USER+1...
Function Documentation
◆ qHash()
uint Editor::qHash ( const PluginDependency &  value)
