Editor API
UnigineEditor public API
Editor::AssetManager Class Referencefinal
This class is used to manage assets in the Editor. You can check if an asset with the specified GUID exists, get its file path, or subscribe for signals to perform certain actions when an asset is added, moved, updated, or deleted. More...
#include <AssetManager.h>
Inheritance diagram for Editor::AssetManager:
Signals
void added (const Unigine::UGUID &guid)
 This signal is emitted when a new asset is added, with the asset's GUID as an argument. More...
void removed (const Unigine::UGUID &guid)
 This signal is emitted when an asset is deleted, with the asset's GUID as an argument. More...
void changed (const Unigine::UGUID &guid)
 This signal is emitted when an asset is modified, with the asset's GUID as an argument. More...
void moved (const Unigine::UGUID &guid)
 This signal is emitted when an asset is moved to another location, with the asset's GUID as an argument. More...
Static Public Member Functions
static AssetManager * instance ()
 Returns the instance of the AssetManager class. This method is used to subscribe to signals. More...
static bool hasAsset (const Unigine::UGUID &guid)
 Returns a value indicating whether an asset with the specified GUID exists. More...
static bool hasAsset (const QString &s_filepath)
 Returns a value indicating whether an asset with the specified file path exists. More...
static QVector< Unigine::UGUID > assets ()
 Returns the list of GUIDs for all existing assets. More...
static QVector< Unigine::UGUID > assets (const QString &dirpath)
 Returns the list of GUIDs for all assets existing in the specified directory. More...
static QString assetFilePath (const Unigine::UGUID &guid)
 Returns the path to the asset file by its GUID. More...
Friends
class Editor::Application
Detailed Description
Member Function Documentation
◆ added
void Editor::AssetManager::added ( const Unigine::UGUID &  guid)
signal
◆ assetFilePath()
static QString Editor::AssetManager::assetFilePath ( const Unigine::UGUID &  guid)
static
Parameters
guidGUID of the asset to find the path for.
◆ assets() [1/2]
static QVector<Unigine::UGUID> Editor::AssetManager::assets ( )
static
◆ assets() [2/2]
static QVector<Unigine::UGUID> Editor::AssetManager::assets ( const QString &  dirpath)
static
Parameters
dirpathPath to a directory containing assets.
◆ changed
void Editor::AssetManager::changed ( const Unigine::UGUID &  guid)
signal
◆ hasAsset() [1/2]
static bool Editor::AssetManager::hasAsset ( const Unigine::UGUID &  guid)
static
Parameters
guidGUID of the asset to be checked.
◆ hasAsset() [2/2]
static bool Editor::AssetManager::hasAsset ( const QString &  s_filepath)
static
Parameters
s_filepathPath of the asset to be checked.
◆ instance()
static AssetManager* Editor::AssetManager::instance ( )
static
Returns
AssetManager class instance.
Example:
, this, &SomeClass::asset_changed);
◆ moved
void Editor::AssetManager::moved ( const Unigine::UGUID &  guid)
signal
◆ removed
void Editor::AssetManager::removed ( const Unigine::UGUID &  guid)
signal
Friends And Related Function Documentation
◆ Editor::Application
friend class Editor::Application
friend
