Editor API
UnigineEditor public API
Editor::PluginInfo Class Reference
This class it is responsible for plugin loading/unloading and contains all necessary plugin metadata (name, version, dependencies, etc.). It can also be used to check the current plugin state and get information on errors (if any). More...
#include <PluginInfo.h>
Public Types
enum  State {
  State::INVALID, State::READ, State::RESOLVED, State::LOADED,
  State::RUNNING, State::STOPPED, State::UNLOADED
 Current plugin state. More...
Public Member Functions
 PluginInfo ()
 ~PluginInfo ()
const QString & name () const
 Returns the name of the UnigineEditor plugin. More...
const QString & version () const
 Returns the version of the UnigineEditor plugin. More...
const QString & vendor () const
 Returns the vendor of the UnigineEditor plugin. More...
const QString & description () const
 Returns the description of the UnigineEditor plugin. More...
const QString & compatibleVersion () const
 Returns version of the plugin considered as compatible. More...
const QVector< PluginDependency > dependencies () const
 Returns the list of dependencies for the plugin. More...
const QString & absoluteFilePath () const
 Returns an absolute filepath to the corresponding plugin's binary file. More...
bool hasError () const
 Returns true if a plugin error has occurred. If the result is positive, you can use the errorString() method to get detailed error information. More...
const QString & errorString () const
 Returns a string describing a plugin error. More...
State state () const
 Returns the current plugin state. More...
bool isInstanceOf (const QString &name, const QString &version) const
 Returns true if the plugin can be used to resolve a dependency of the given name and version. More...
Plugin * plugin () const
 Returns the Plugin interface. More...
Friends
class PluginManagerPrivate
Detailed Description
Member Enumeration Documentation
◆ State
Enumerator
INVALID
Initial plugin state indicating that initialization either has not yet started or an error has occurred during initialization.
READ
Plugin metadata is read and processed successfully.
RESOLVED
All required dependencies of the plugin are resolved.
LOADED
The plugin's dynamic link library is successfully loaded and processed by the dynamic linker.
RUNNING
The plugin is running - i.e., the Editor::Plugin::init() method was executed successfully.
STOPPED
The plugin is stopped - i.e., the Editor::Plugin::shutdown() method was called.
UNLOADED
The plugin's dynamic link library is successfully unloaded from memory.
Constructor & Destructor Documentation
◆ PluginInfo()
Editor::PluginInfo::PluginInfo ( )
◆ ~PluginInfo()
Editor::PluginInfo::~PluginInfo ( )
Member Function Documentation
◆ absoluteFilePath()
const QString& Editor::PluginInfo::absoluteFilePath ( ) const
◆ compatibleVersion()
const QString& Editor::PluginInfo::compatibleVersion ( ) const
◆ dependencies()
const QVector<PluginDependency> Editor::PluginInfo::dependencies ( ) const
◆ description()
const QString& Editor::PluginInfo::description ( ) const
◆ errorString()
const QString& Editor::PluginInfo::errorString ( ) const
◆ hasError()
bool Editor::PluginInfo::hasError ( ) const
◆ isInstanceOf()
bool Editor::PluginInfo::isInstanceOf ( const QString &  name,
) const
Parameters
namePlugin name.
versionPlugin version.
◆ name()
const QString& Editor::PluginInfo::name ( ) const
◆ plugin()
Plugin* Editor::PluginInfo::plugin ( ) const
◆ state()
State Editor::PluginInfo::state ( ) const
Returns
One of the PluginInfo::State enum values.
◆ vendor()
const QString& Editor::PluginInfo::vendor ( ) const
◆ version()
const QString& Editor::PluginInfo::version ( ) const
Friends And Related Function Documentation
◆ PluginManagerPrivate
friend class PluginManagerPrivate
friend
