Editor API
UnigineEditor public API
Editor::Undo Class Reference
Undo manager class. This class is used to manage undo/redo operations for user actions in the Editor. More...
#include <Undo.h>
Inheritance diagram for Editor::Undo:
Signals
void worldModified ()
 This signal is emitted when an action brings any changes to the scene. More...
void activity ()
 This signal is emitted when an action has been applied, undone, redone, or pushed to transaction stack. More...
Static Public Member Functions
static Undo * instance ()
 Returns the instance of the Undo class. This method is used to subscribe to signals. More...
static void apply (Action *action)
 Applies the specified action. More...
static void push (Action *action)
 Pushes the specified action to the transaction stack. More...
static void undo ()
 Reverts the last action in the stack. More...
static void redo ()
 Redoes the last action that was undone (reverses the undo method). More...
static void reset ()
 Clears the undo/redo stack. More...
static void begin ()
 Begins a transaction (i.e. a sequence of actions applied to be applied or reverted as a whole). Use commit() to apply all actions of the current transaction, or rollback() to revert them. More...
static void commit ()
 Commits the last transaction (i.e. a sequence of actions applied since the last call of the begin() method). More...
static void rollback ()
 Reverts the last transaction (i.e. a sequence of actions applied since the last call of the begin() method). More...
Friends
class Editor::Presenter
Detailed Description
Member Function Documentation
◆ activity
void Editor::Undo::activity ( )
signal
◆ apply()
static void Editor::Undo::apply ( Action *  action)
static
Parameters
actionAction to be applied.
◆ begin()
static void Editor::Undo::begin ( )
static
◆ commit()
static void Editor::Undo::commit ( )
static
◆ instance()
static Undo* Editor::Undo::instance ( )
static
Returns
Undo class instance.
Example:
, this, &SomeClass::world_modified);
◆ push()
static void Editor::Undo::push ( Action *  action)
static
Parameters
actionAction to be pushed.
◆ redo()
static void Editor::Undo::redo ( )
static
◆ reset()
static void Editor::Undo::reset ( )
static
◆ rollback()
static void Editor::Undo::rollback ( )
static
◆ undo()
static void Editor::Undo::undo ( )
static
◆ worldModified
void Editor::Undo::worldModified ( )
signal
Friends And Related Function Documentation
◆ Editor::Presenter
friend class Editor::Presenter
friend
