MarioBag Posted November 11, 2022 Share Posted November 11, 2022 Dear members of Unigine. Does anybody know if is possible to create retro-reflective materials in Unigine? . Retro reflection is used for improve visibility of signs and road element at night. I've tried looking for tutorials, posts in the forum and even the Unigine "art samples" project. And was not able to find something I can use. Quote Retroreflection occurs when a surface returns a large portion of directed light beam back to its source. Retroreflective materials appear brightest to observers nearest the light source (such as a motorist). Quote and screenshot taken from https://www.3m.com/3M/en_US/road-safety-us/resources/road-transportation-safety-center-blog/full-story/~/road-signs-retroreflectivity/?storyid=328c8880-941b-4adc-a9f9-46a1cd79e637 A simple material with high reflection values would not work as: We are only interested in reflect the light. The visibility of the reflected light depends on: Intensity of light source Position and orientation of the viewer (camera). The closer the viewer is to the "cone of reflection" the stronger the visibility of the reflection. I do not know if I need a special shader for it (Shaders are not my strength) . But I think I have a small idea of the basic concept. I can imagine I would need a a texture with a pattern (could be bars, hexagons, etc) . This texture needs to be use as a mask. And only that mask needs to be reflective. But, this reflection needs to consider points 1 and 2 above. Screenshot taken from https://svigraphics.com/custom-vinyl-graphics/reflective-chevron-panels/ Thanks in advance for your time Link to comment
romain.janil Posted November 11, 2022 Share Posted November 11, 2022 I guess it would need to be a special shader, kind of a special BRDF or modification of GGX model... Anyway I think it can be "faked" also with a material graph with view/shading manipulation, but immediate problem I see with textures with too small micro patterns is mipmaps and anti-aliasing (either it would be too blured or too crisp with moire if no mipmap applied) so it would never get right at any distance...so a more simple approach would be needed (not trying to exactly mimic real material) have a look at : https://github.com/RDTG/UnrealEngineRetroreflections for the shader part, it's implemented in UE, it should be easily ported to Unigine. Link to comment
sebastian.vesenmayer Posted November 29, 2023 Share Posted November 29, 2023 Hello Unigine support, can someone answer to this topic, we would also need such a material. Thanks :) Link to comment
silent Posted November 30, 2023 Share Posted November 30, 2023 Hi Sebastian, In 2.17.x SDK you can check material example built with material graph in Art Samples: It's located in <ART_SAMPLES>data\art_samples\material_examples\retroreflective_shading directory. Thanks! 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
