Guest shane.ploenges Posted September 16, 2011 Share Posted September 16, 2011 When trying to save out Normal, Parallax and Height maps from the NormalMapper in Resource editor, the files will not save. the error is as follows: Image::save():unknown format of "c:/maps/filename_n" file Using windows 7 64 bit and resource editor version from UnigineTools-2011-08-12 Link to comment
Guest shane.ploenges Posted September 16, 2011 Share Posted September 16, 2011 I solved this - you will get this error if you do not manually add an extension for the filetype to the filename when saving.. merely selecting a file type from the drop down list is not enough. i would consider this a bug. Link to comment
manguste Posted September 21, 2011 Share Posted September 21, 2011 Yep, right now the drop-down list just shows available options, but I'll pass the word to our developers. Link to comment
manguste Posted September 22, 2011 Share Posted September 22, 2011 Upd. Added to the to-do list. Link to comment
