sebastian.vesenmayer Posted May 9, 2022 Share Posted May 9, 2022 Hi, I want to create a particle system where at the beginning the particles will fade in by an interpolated alpha value an not by increasing the size. What Setting do I need to change? At the moment they just pop in when particle is created. Thanks Link to comment
sareth Posted May 11, 2022 Share Posted May 11, 2022 Hi, Sebastian! You can do it via particle system material if you change Albedo Mode from color to curve. From left to right the graph represents the lifetime of the particles. 1 1 Link to comment
sebastian.vesenmayer Posted May 11, 2022 Author Share Posted May 11, 2022 Thanks for the hint, I haven't found it. :) This can be closed. 1 Link to comment
