karim.salama Posted January 26, 2022 Share Posted January 26, 2022 Hello, In Unigine's Editor plugin implementation, there is no "update" function. So I made an update function which is executed on a thread which starts in init and terminates in shutdown. Apparently, nodes cannot be added to the world on a thread other that the main thread. Why? Is there a workaround for this? void add_dummy_to_selected() { auto dummy = Unigine::NodeDummy::create(); dummy->setShowInEditorEnabled(true); dummy->setOwner(false); if (Editor::SelectorNodes* snodes = Editor::Selection::getSelectorNodes()) { auto nodes = snodes->getNodes(); if (nodes.size() >= 1) nodes[0]->addChild(dummy); } } void add_dummy_with_thread() { std::thread thread = std::thread(&add_dummy_to_selected); thread.join(); } In the example above, using add_dummy_to_selected works, but add_dummy_with_thread doesn't. Thanks in advance Link to comment
turbo Posted January 27, 2022 Share Posted January 27, 2022 Hello. You can use System Logic and World Logic to implement your own update func. I have attached the source code for example. I modified the source code of our MaterialsPlugin sample. Thanks MaterialsPlugin.h MaterialsPlugin.cpp 1 1 Link to comment
karim.salama Posted January 27, 2022 Author Share Posted January 27, 2022 Hi @turbo, Ok thank you. But why not use Editor Logic? Link to comment
