eoailg Posted October 28, 2020 Share Posted October 28, 2020 Hello Everybody, I recently tried to import my animated tank tracks from blender. The animation works by moving the threads to the position of the following one. After that, they should jump back to their starting position again. The problem is however, that the threads do not "teleport" from end to start position (like they do in blender, where i created the animation), but rather move rapidly to the beginning again. Especially on low speeds, you can see it clearly. I could not find any post relating to this specific post. Does anyone know how to deal with this? tank_track.mp4 Thank you for your time. Link to comment
silent Posted October 28, 2020 Share Posted October 28, 2020 eoailg Could you please send us this FBX file with animation? Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
eoailg Posted October 28, 2020 Author Share Posted October 28, 2020 There you go. tank_track_sep.fbx Link to comment
honya Posted October 28, 2020 Share Posted October 28, 2020 (edited) Ignore the last animation frame, then you don't get blend between last and first frame of animation, when you set time to animation. int numFrames = mesh.get()->getNumAnimationFrames(animId); // ignore last frame from number of animation frames if (time > (numFrames - 1)) { // ignore last frame // when mesh is returning to start position time = time - numFrames + 1; } mesh.get()->setFrame(layer, time); Edited October 28, 2020 by honya Link to comment
silent Posted October 28, 2020 Share Posted October 28, 2020 eoailg In order to make it work inside the Editor I guess you need to do a full 360 degrees circle animation, so it will start to loop correctly without any code. Otherwise, you can follow the previous advice from @honya and implement your custom animation play logic. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
