rohit.gonsalves Posted August 19, 2020 Share Posted August 19, 2020 (edited) Hello There, I am trying following code to use and render MeshDynamic. But I am not able to render it. What could be the problem? //There are my declarations MeshDynamicPtr m_objMeshDynamic; MeshDynamic::Attribute m_objMeshDynamicAttributes[1]; MaterialPtr m_objMaterial; Here is an init method m_objMeshDynamicAttributes[0].offset = 0; m_objMeshDynamicAttributes[0].type = MeshDynamic::TYPE_FLOAT; m_objMeshDynamicAttributes[0].size = 3; m_objMeshDynamic = MeshDynamic::create(MeshDynamic::DYNAMIC_ALL); m_objMeshDynamic->setVertexFormat(m_objMeshDynamicAttributes, 1); m_objMeshDynamic->allocateVertex(3); m_objMeshDynamic->allocateIndices(3); m_objMeshDynamic->clearVertex(); m_objMeshDynamic->clearIndices(); //Vertex 1: m_objMeshDynamic->addVertexFloat4(0, 10, 10, 10); //Vertex 2: m_objMeshDynamic->addVertexFloat4(0, -10, 10, 10); //Vertex 3: m_objMeshDynamic->addVertexFloat4(0, 10, 10, -10); m_objMeshDynamic->addTriangles(1); //front m_objMeshDynamic->addIndex(0); m_objMeshDynamic->addIndex(2); m_objMeshDynamic->addIndex(1); m_objMeshDynamic->flushVertex(); m_objMeshDynamic->flushIndices(); m_objMaterial = Materials::findBaseMaterial("mesh_base"); In the render method RenderState::saveState(); RenderState::clearStates(); RenderState::flushStates(); RenderState::setMaterial(m_objMaterial); RenderState::setPolygonCull(RenderState::CULL_NONE); m_objMeshDynamic->bind(); m_objMeshDynamic->render(MeshDynamic::MODE_TRIANGLES, MeshDynamic::FLUSH_ALL); m_objMeshDynamic->unbind(); RenderState::restoreState(); Nothing is visible. Am I doing something wrong. Or I mapped wrong perception between MeshDynamic and DX11 calls that might be called behind? Please advise. Rohit Edited August 22, 2020 by rohit.gonsalves Changed the topic to solved. Link to comment
devrom Posted August 20, 2020 Share Posted August 20, 2020 Hello Rohit, 1. Maybe you should check if you are using addTriangles correctly. After reading the documentation of the other add* methods I think you do not need to use this here. 2. It is possible that you have to write a custom shader for your vertex format. For example the documentation of ObjectDynamic contains this: Quote ObjectDynamic class requires a custom shader for rendering, no built-in shaders are available. Maybe the mesh_base material can not handle this. Best regards Link to comment
rohit.gonsalves Posted August 22, 2020 Author Share Posted August 22, 2020 (edited) Thank you for pointing the mistake in the code above @ipg_rom. I could able to get it work. I have created an ObjectExtern and in the render call for passes, it is using the custom deferred material and rendering mesh dynamic. Rohit Edited August 22, 2020 by rohit.gonsalves Link to comment
