No "lib" sub-folder in the SDK folders, as indicated in the linux setup part of the doc
I've noticed the following point in the linux documentation https://developer.unigine.com/en/docs/2.10/code/environment/linux?rlang=cpp
You may also need to set the following environment variables:
  • Add to $LD_LIBRARY_PATH variable locations of the following directories: <UnigineSDK>/lib.
Re-login to make the changes in ~/.profile take effect.
but there is not "lib" sub-folder in the SDK folders
Edited by laurent.ongaro
