Koksharov.Vasilij Posted May 29, 2018 Share Posted May 29, 2018 Hello! We use Unigine 2.7 Problem with instancing. We make some node instances. Then we edit node parameters (change material or rotate objects) inside instance and apply changes. But other instances not react and change their states after restart editor only. We make everything exactly like in this tutorial: https://developer.unigine.com/en/docs/2.7/editor2/instancing_nodes/ . Try it in clean default projects and several PC's. What we do wrong? Thanks. Link to comment
morbid Posted May 30, 2018 Share Posted May 30, 2018 Hello Vasilij, this is known bug in 2.7. Good news is that we've fixed this. In the upcoming SDK 2.7.1 it works fine. The update will be available in 1-2 weeks. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
