yraida.morete Posted April 19, 2011 Share Posted April 19, 2011 Dear all, I have some questions for you :( : 1.-which is the best way to get a 3072*768 app with three screens? 2.-how can I run 2 or more instances at the same time? 3.-how can I build 3 viewports in the same window? Thank you very much! Link to comment
binstream Posted April 26, 2011 Share Posted April 26, 2011 1.-which is the best way to get a 3072*768 app with three screens? You can simply set the resolution via CLI options: -video_mode -1 -video_width 3072 -video_height 768 and use AMD Eyefinity technology with 3 screens, for example. 2.-how can I run 2 or more instances at the same time? You can run the application one more time, but it's not recommended due to performance problems. 3.-how can I build 3 viewports in the same window? Use ObjectGui: https://developer.unigine.com/en/docs/1.0/code/scripting/library/objects/class.objectgui Link to comment
ulf.schroeter Posted August 17, 2011 Share Posted August 17, 2011 New UNIGINE SDK 2011-08-12 functionality for handling multiple independent screens Link to comment
