ControlsJoystick SetCooperativeLevel() failed
Greetings! I'm building an application that's using the Qt project template. I'm referencing the ControlsJoystick, however upon initialization, I get the following console log:
Loading "dinput8.dll"
ControlsJoystick::updateEvents():SetCooperativeLevel(): failed
At this point the joystick is non working.
If I run a non-Qt based project, the joystick seems to be ok. Based on the docs, this has something to do with joystick control exclusivity mode ( the cooperative level flags ).
How would you suggest I should approach the joystick initialization?
Hi Tsetso,
Currently there is a known issue related to the joysticks being handled with 3rd party integrations (such as Qt or SDL). Right now we are not ready to provide a solution. We will check what else we can do before the 2.7.1 update.
